leaking water 2001 520MXC dual sport
Hey all.  So I've noticed water dripping from the small port in the water pump housing when I'm sitting at a stoplight.  Does this mean that the waterpump is bad or just that the seals are deteriorating?
I've done some research, it appears the older KTMs like mine I need to pull the head cover off to change the seal?  I watched the vid by TravisD_37 that mentions a conversion kit to fix that engineering SNAFU, but that was years ago....he hasn't been active on TT for a couple years now.  Anyone else know where I can get info on this?  I also read something about changing the camshaft bearings to prevent a premature catastrophic event.  Anyone have any good info on that?
Also, should I change the thermostat or just take it out completely?  I'm down in Florida, it is pretty warm down here most of the time and my bike does get pretty damn hot....it seems to run better when it's colder.
I'm also having a performance problem with my KTM.  It doesn't idle/run smooth, it's very erratic and sometimes hesitates under power, almost like it's about to stall.  I've looked into that, it seems that the KTM jetting and needle used in the FCR carbs are also an engineering SNAFU.  Of course the answer from JD Jetting is to buy their "fix it all" jet kit....I'm on a budget and kinda cynical so I'm looking for more of an answer than the JD "fix it" kit....
Are the ignition boxes on KTMs pretty good?  Durable and dependable?  Been wondering if it's the CDI circuitry in the ignition box taking a dump, which is causing the intermittent performance issues.....
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
