Starter relay wiring?
Simple question, probably over thinkinbg it but I disconnected the wiring to the starter relay/solemoid awhile ago and not sure the polarity. is the terminal closest to the red wire positive and the connection closet to the blue negative?
I look at the clymer wiring diagram and its not helpful and dont see anything marked on the relay
Is this picture the correct placement?
Both terminals are positive.  Makes no difference where the cables connect.  Probably the cables will tell you where they want to go when you mount the relay.  You have a cable from the battery to the relay and a cable from the relay to the starter.
agree....sometime these are convenient spots to pick up battery feed to accesories so just make sure that if there are extra wires they would go to the bat side.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
