Hot cams?
Thinking about installing hot cam into my 450r I was just wondering do I need to change my stock valves for this cam? Do I need to change anything to be able to run this? Also which stage is better stage1 or 2? Thanks
All depends on where you are looking for more power and what mods are done to bike. Stage 1 & 2 use stock springs, and some of the Builders series cams require stronger springs. I put a stage 1 in my 2013 CRF450 and it runs much better than stock. I race mostly MX, the bike had plenty of top end speed, just needed to get there faster, stage 1 fixed it.
Everything motor wise is stock the only thing I've done to the bike is put a slip on exhaust on it. It's a 2006 crf450r
I have an RHC cam that runs on stock springs  An other engine builder and freind terry Varner had tryed the hot cams first and ended up liking the RHC cam the best .
Like the stage 2 hot cam?
No
The stage two cam has a more 'peaky' feel to it.
The OEM '02R cam does not.
CRF DOC, on 07 Jan 2015 - 6:24 PM, said:snapback.png
Resurrected for my buddy Amazing Ricardo...  :)
I put this list together a few years ago. Thought I'd repost it for reference.
Honda Cams
Honda 2004-2005 HRC Cam - Part # 14110-NLZ-650
Really strong to top end cam, with a decent mid range, but lacks bottom end.
Intake Lift(inches): .390
Exhaust Lift(inches): .350
Intake Lobe Center (degrees): 110
Exhaust Lobe Center (degrees): 105
Intake Duration (degrees at .040"): 260
Exhaust Duration (degrees at .040"): 260
Honda 2002 CRF450R Cam - Part # 14110-MEB-670
A good all around cam, strong bottom and really strong mid range with a excellent top end as well.
Intake Lift(inches): .380"
Exhaust Lift(inches): .356"
Intake Lobe Center (degrees): 106.5
Exhaust Lobe Center (degrees): 107
Intake Duration (degrees at .040"): 249
Exhaust Duration (degrees at .040"): 272
Honda 2003 CRF450R Cam - Part # 14110-MEB-770
A good strong bottom and mid range cam. Slightly detuned from the 2002 R cam.
Exhaust Lift(inches): .336"
Intake Lobe Center (degrees): 109
Exhaust Lobe Center (degrees): 109
Exhaust Duration (degrees at .040"): 262
Honda 2006-07 HRC & Honda 2004,2005,2006 CRF450R Cam - Part # 14110-NLZ-610 & 14110-MEN-670
Really strong bottom with a decent mid range.
Intake Lift(inches): .374"
Exhaust Lift(inches): .313"
Intake Lobe Center (degrees): 107
Exhaust Lobe Center (degrees): 110
Intake Duration (degrees at .040"): 248
Exhaust Duration (degrees at .040"): 268
HotCams
HotCams Stage 1 - Part #1016-1
Decent bottom end and midrange increase. Signs off early.
Intake lift (inches): .378"
Exhaust lift (inches): .343"
Intake lobe center (degrees): 106.5
Exhaust lobe center (degrees): 103.5
Intake duration (degrees at 1mm): 237.5
Exhaust duration (degrees at 1mm): 268.5
HotCams Stage 2 - Part #1024-2
Good midrange and top end increase, good all-around cam. Lacks bottom.
Intake lift (inches): .402"
Intake duration (degrees at 1mm): 248
HotCams Stage 3 - Part # 1056-3
More top-end power than Stage 2. Will work well for TT and big bore/strokers.
Intake lift (inches): .409"
Exhaust lift (inches): .356"
Intake lobe center (degrees): 116
Exhaust lobe center (degrees): 104.5
Intake duration (degrees at 1mm): 251.5
Exhaust duration (degrees at 1mm): 265
