German Magazine 350 4-Stroke Enduro Shootout
German Magazine:
Beta RR 350 EFI, Husqvarna FE 350 KTM 350 EXC-F and Sherco 300 SEF-R
350cc sport bikes in the comparison test
In the 350ern sport bikes, the air is burning. Because more than half of all four-stroke sport bikes sold in this class. The battle for dominance in the undergrowth raging violently. Beta RR 350 EFI, Husqvarna FE 350 KTM 350 EXC-F and Sherco 300 SEF-R in the comparison test.
There reigns presented for the 2012 season founder of this segment, the KTM 350 EXC-F .With each year about 7,000 machines sold is currently selling sports enduro world. The success of the competition calls on the scene. For example, the Beta RR 350 EFI. The addition stands for Electronic Fuel Injection, signaled on the model 2015, the premiere of the fuel injection in the range of the Italians. The Husqvarna FE 350 reports on claims. A rear frame made of plastic, a closed cartridge forks and - most importantly - an indirect lever monoshock distinguish it from its intragroup KTM half-sister. This self-confident presents the Sherco 300 SEF-R. The southerners equip their bikes - the first off-road machinery manufacturer ever - since 2004 with injection from. In-house engines are already a matter of course in only twelve years young sports enduro history of the manufacturer of Nimes. And they all want the same thing: the KTM discharged from the podium.
4th place: Sherco 300 SEF-R
Sherco 300 SEF-R.
Photo: Gargolov
304 cubic: With a displacement disadvantage of nearly 50 cc goes Sherco300 SEF-R with her ​​based on the 250 chassis engine into the race. The reason why the Sherco engine characteristically positioned completely different from the rest of the trio. Speed ​​is the pound, with the overgrown the DOHC single. On the Motocross Track, the training area of ​​the bulk of the Enduro pilots and basis for most cross country trails in this country no problem. With the finger on the clutch at corner exit bring the micromotor as early as possible on tours and then rotate, then it goes ahead with the Sherco. Up to 13,000 / min - at least 1200 Tours higher than the rest of the test field - cheered the 43-hp single-cylinder high.
With noticeably less punch than its larger displacement colleagues (see performance chart) calls the 300-blowing set by the pilot attention. Who can go down the speed, losing valuable meters. Attention of the pilot of Sherco 300 SEF-R should be ahead of the curve. In order to reduce the drag torque of the motor, stepper motor of the French Synerject injection holds still for a moment, opened a little in push mode, the throttle valve. In practice, the engine pushes shortly after with increased speed and only then drop to idle level. Getting used to.
pfeil.gif 250 cc sport bikes from Gas Gas, Husqvarna and KTM in the test
pfeil.gif About Sherco
For the Sherco 300 SEF-R compensated with the handiest chassis in its class. With delicate leg pressure they articulated on the cross slope in curves a, holds the razor-sharp line, feels despite objectively weighed 110 kg significantly easier as the 109-116 pound competition.Chapeau. This ease throws them in the Enduro terrain in the pan. Clean balanced and so trialt over boulders passages, easy to calculate stresses the clean engine dosed the front wheel. The optional, selectable via a handle switch emphasized tame mapping it never needs in this gentle characteristics.
The harmony in the rough atmosphere disturbs rather appealing hakelig Open cartridge front fork from WP Suspension. The more slippery it gets, the more shall the torque shortcoming of the Sherco 300 SEF-R in the background, let the pilot easily find traction, zirkeln the tightest bends through the undergrowth and the Frenchwoman clearly define it - as Enduro purest water, for more than four square next to some finetuning in suspension and engine tuning one thing missing: 50 cc more displacement.
Course 2: Beta RR 350 EFI
Beta RR 350 EFI.
Photo: Gargolov
Fine-tuning? In this word, the pilots of the Beta RR 350 EFI pointed ears. As an in-house engine valve actuation via rocker arms and separate oil circuit for motor and would gear not already settled at the upper end of the current Enduro engine technology, the Italians now also applied an injection. The information provided by Synerject as in the Sherco 300 SEF-R system works perfectly: easy starting, instantaneous throttle response, no increased idle and no drips.
Alive and kicking the propellant charge depends on the gas, animated with a low internal friction and running almost velvety, untwist the aisles. Lens, the Beta RR acquiesces 350 EFI - in contrast to its more than 12,000 / min rotating predecessors - this year, although with moderate maximum speed of 10,500 / min. The music does not even need. The fact that the propellant surpassed in the middle of all speed fellow activists (see performance chart), even it shows him in his famous education at. And because he otherwise unremarkable potent behaves with butter-smooth operating transmission, to forgive him that the Husqvarna FE 350 and KTM 350 EXC-F press in the last third of three speed hp more peak power to the role.
pfeil.gif Beta RR 350 EFI model 2015 Fahrbericht
pfeil.gif About beta
Even chassis of the Beta RR 350 EFI concentrated more on their strengths enduristischen.As a trial bike soaks up the RR with the relatively soft-adjusted Sachs shock elements on the stone fields, but this alignment must pay on the motocross runway tribute and rides there deep in forciertem pace in their spring travel. It also makes the stresses towering steering head heavily to weight the front wheel turns. Even Max by ambitious standpipes not transform the beta for Eckenwetzer. But because the Florentine clearly focused on the enduro use and so finely ground in this model year as has never thrown in their red skin, only one thing left to say: Complimenti for second place. She shares with the KTM 350 EXC-F.
2nd place: KTM 350 EXC-F
KTM 350 EXC-F.
Photo: Gargolov
What, only the place of honor for the former sole ruler? No Panic. Because of their outstanding qualities so far has not lost one iota the KTM 350 EXC-F. As before, it is 109 kilograms, the lightest, with 46 hp the strongest and with their spontaneous power delivery and the liveliest of this quartet. But their potential is revealed only to those who know how to make their contribution to the common Eckenwetz.
artikel.gif Comparison Test: KTM 350 EXC-F KTM 450 EXC against
pfeil.gif All products for KTM 350 EXC-F
The lightweight front end demands of the bends a dedicated physical exertion and the small acceleration waves little sensitive responsive PDS shock absorber strong pressure on the footrests. Who moved the KTM 350 EXC-F active and engaged, is banging with any of these four bikes faster on motocross tracks. In more complicated or slippery terrain enduro require the class in comparison snappy hands-motor states and tight hindquarters However, according to an experienced pilot who skillfully glättendem finger on the clutch and targeted loading and unloading of the suspension builds traction. Then the impulsive KTM enters the same step of the podium as the mild-mannered Beta RR 350 EFI - only just coming from the opposite direction.
1st place: Husqvarna FE 350
Husqvarna FE 350th
Photo: Gargolov
A KTM with redirection instead of pretty gnarly appealing PDS shock absorber, which had some of the Enduro customers wished for. Wherein the modified Husqvarna suspension has far-reaching consequences.In fact, the ride on the Husqvarna FE 350 is significantly different from that on the KTM 350 EXC-F. Especially the little front of the EXC soaked in the FE is a neutral-feeling front section. On smooth terrain, the front wheel bites aggressively into the ground, in the extended Geschlängel meets the FE ruts precise.
Their part in carrying the good responsive fork showing clearly superior to also derived from WP Suspension open cartridge forks in the KTM and Sherco 300 SEF-R. Sensitive put away the Hebelei activated on the Monoshock acceleration waves and tensions with its successful coordination accomplished to delicate balancing act in singletrack to the high-speed performance at the cross slope. However: the playful handling of the KTM 350 EXC-F does not have the 113 kilograms compared four kilos heavier Husqvarna FE 350.
pfeil.gif News from Husqvarna at EICMA 2014
pfeil.gif About Husqvarna
The order which is now placed in the middle strut inevitably run around in an arc Suction costs the technically adopted unchanged from the KTM FE engine in the upper rpm range a little power (see diagram). Also from low revs saith the propellant charge a bit more subdued in. For this, can the gentler propellant in tricky terrain easier measured and together with the sensitive rear suspension for the best traction of the Gang of Four. And because the Husqvarna with their tuned for a wide range of applications running gear, emphasizes neutral handling and ultimately still potent engine is the most uniform and efficient overall package, the majority of off-road drivers for Husqvarna FE 350 should mainly be one thing: fire and flame.
Edited by HuskyRips
Hard to follow with the translator. I rode all but the Beta and feel a little different. I liked the FE350 (2014) over the KTM (2015) in everything but all out power. Sherco (2014) was the leader in handling and agility, lightest feel of the bunch. The Beta's I owned and rode are too far off from the new 2015 models to give a comparison to the other newer bikes.
I agree about the translator.
I just sold my '14 KTM 350 EXC-F after riding it about 80hrs/2,000 miles.  It was a GREAT bike, the only reason I sold it was because I was looking for a new project and a I sold it to a good acquaintance of mine locally.
My current bike....'14 Husky FE250 that I converted to street legal.....thank you Nevada for allowing me to pay you a small registration fee :)......while doesn't have as much peak torque/horsepower as the KTM 350, because of the  combination of power delivery and handling traits make it a more FUN bike to ride.   Definitely  NOTHING  wrong with the KTM 350 but I like this Husky better !
And as far as the suspension......I set the shock to the factory recommended "comfort" setting and the forks full soft on compression and "comfort" setting for the rebound.  Done.  Does GREAT for the solid intermediate riding that I do out here in the desert.
Regarding Beta......I've owned an '11 450RR that I also converted to NV street legal status.   I liked the bike a LOT !
I probably won't buy another Beta mainly because .....again this is just my opinion......I feel like I'm buying it from a guy/guys out of their backyard garage.  And.....not only is the resale much worse than KTM and probably Husky there are almost no buyers at any price.   Which I know is a factor in the previous statement.   This is from actual experience when I went to sell my Beta.  I suppose if I could accept these facts and buy a Beta 250RR ('15 model year) and ride it until it dies.....a very very long time.....then throw it away ....I'd buy one.  But I like the "project" factor too much to do this.
Just my .02 maybe :)
Edited by Rider777
  • Similar Content
    • By MotoXRacer_19
      Does anyone know how to, or if you can, change your AMA number? The race number, not the full thing.
    • By Mike Michel's
       Would anybody know how many watts my 99 TE 410 stator
    • By KX290F Pilot
    • By Bryan Bosch
      Rockstar Energy Husqvarna Factory Rider Starts his Quest to Defend Cross-Country Rallies World Championship
      March 15, 2018 – (Motor Sports Newswire) – Rockstar Energy Husqvarna Factory Racing’s Pablo Quintanilla will re-start his 2018 international rally racing campaign on March 24 to 29 at the Abu Dhabi Desert Challenge in the United Arab Emirates. Working hard towards returning to full competitive fitness following a foot injury sustained during the closing stages of the Dakar Rally, Pablo’s teammate Andrew Short is expected to join the Rockstar Energy Husqvarna Factory Racing squad at the 2018 Merzouga Rally in mid-April.
      With the Abu Dhabi Desert Challenge playing host to the opening round of the 2018 FIM Cross-Country Rallies World Championship, the event in the UAE will see Pablo Quintanilla begin the defence of his FIM Cross-Country World Championship title. Securing eighth overall at the 2018 Dakar Rally in January, the Chilean rally star is already looking forward to a solid return to racing aboard his FR 450 Rally machine.
      Successfully wrapping up his debut participation at the prestigious Dakar Rally with a top 20 result, Andrew Short has been recuperating from a fractured tibia and fibula on his lower right leg. Resuming his training sessions in the middle of March, the American has his eyes set on making a return to racing at the Merzouga Rally on April 15/20, in the dunes of Morocco.
      Celebrating its 28th edition in 2018, the Abu Dhabi Desert Challenge is a six-stage-long rally taking place in the southern part of the United Arab Emirates. Kicking off with the traditional Super Special Stage on Saturday, March 24, the event will continue with five more days of racing in the Liwa Desert before competitors reach the finish line inside the Yas Marina circuit on March 29, 2018.
      Pablo Quintanilla: “Abu Dhabi will be our first race after the Dakar and I’m really looking forward to it. It’d be good to start the season carrying the #1 plate on my Husqvarna as the reigning champion. With it being the first race for the new season, it is important for everybody. My goal is to get a good race pace from the beginning in order to be inside the group of leading riders. The season will be long and my plan is to continue improving my pace as the racing goes on. I want to get back my racing speed and also remain strong throughout the event in Abu Dhabi. Taking place in deep sandy dunes, the Desert Challenge is always a tough event and it is also highly probable that we will have to race in high temperatures. It’s going to be a challenge but I’m looking forward to it.”
      Husqvarna Motorcycles. Tradition on two wheels since 1903.
      Husqvarna Motorcycles are widely known and respected in the off-road world for a heritage of competition and numerous motocross and enduro world championships. Originally founded in Sweden in 1903, Husqvarna Motorcycles have been designed and manufactured in Mattighofen, Austria since 2013.
      Rockstar Energy Drink
      Rockstar Energy Drink is designed for those who lead active lifestyles – from Athletes to Rockstars. Available in over 20 flavors at convenience and grocery outlets in over 30 countries, Rockstar supports the Rockstar lifestyle across the globe through Action Sports, Motor Sports, and Live Music. For more information visit:
      Source: Husqvarna Motorcycles GmbH
    • By DdrossyD
      Looking for some Wiring Harness, Connections and Installation assistance for installing a Tusk Universal Under the Fender LED Taillight with Brake Light on a Husqvarna 2017 TX300
      The UTFLight comes with a plastic connector that would work with the tusk enduro lighting kit which i'll be removing so that I can plug into the stock harness.
      I've been told the stock harness is the same as what would be included on the TE Model, minus the actual headlight/taillight being present; which is the case for the headlight wiring . it's all there ready to go.  For the taillight/brakelight however there is a bit more to be done.  There are NO wires running to the rear of the bike or within the SubFrame as some have noted
      I'll need to run to existing wires, and could use some guidance for which connectors are needed, if a supplementary harness is required(if so which one) and which wires to connect to on the existing harness.  There is very limited info in the manual (for either bike: TE/TX) or complete color harness diagram with info and connector information anywhere that I could find.
      I also picked up the Tusk Brake Switch Banjo bolt for the Brembo brakes (two wire, bullet connectors) - switch instructions.pdf
      On the Brake side under the front/bottom of gas tank near radiator there is an existing connector (I think for radiator fan) and from it, two unused wires, I would say for tapping into the existing harness.  1 Solid Brown, 1 Yellow/Red -
      Shifter side, near the bottom rear of tank I found taped up cylinder style connector (Someone can enlighten me) i think switch wires ? maybe some terminator,  each with the same color wire in as out.  One is Gray/Black and the other White/Black
      Under the cdi box is a three plug connector with two wires, 1 Brown and 1 White, third unused- i was hopeful this could be the tail light connector but am unsure
      Help on harness, connector names /types and setup is very much appreciated
