Water pump leeking yz 250 2001
Usually better do everything at once if open.  It not always necessary, but CaveMike always feel dumb when him lazy shortcuts come back and bite him on ass.  You not take shortcut and get ass bit.
If any shop that sale everithing like a kit includes cluth gasket and shaft ?
The kits have everything except the shaft, gotta get that separate. If the shaft has any grooving in it at all (which they most always do), you need to replace it. Otherwise the new seal will be leaking again in short order.
Yes, just that side, remove kick start, pull cover!
Shaft always bad. Shaft, he's a bad mother----shut yo mouth!
Crawl back into your cave monkey boy.... Shaft NOT always bad, not replace bearing when replacing seals ,run bad bearing, shaft go bad, or is it you just like to get the shaft because?
thanks for all your help, everithing OEM from motosport.com
Gotta love that 20%, it's better than RMATV/MC as long as they have it all in stock.
