Pwk 38mm in 2006 yz125?
CaveMike get new to him 2006 yz125.  Carb be Mikuni tmx 38mm.  It be leaking and need rebuild.  Maybe float problems, maybe needle jet.  CaveMike going rebuild it, keep fingers crossed.  CaveMike have extra Keihin pwk 38mm from 2005 yz250 laying around.  Him thinking about use pwk in 125.  Anyone do this?
Hi Cave Mike,
I have not seen any of your posts in a while, but I'm glad you are back! I have also recently acquired an 06 YZ 125 (last May). The bike is so much fun that I have only ridden my 250 twice since acquiring the 125. If I remember correctly, you are more of an off road guy than one of those fancy MX guys. A few tips you might find useful for your new mount:
1. Don't screw up the stock carb. I bet your problem is that ethanol has damaged the tip on the float needle. Replace it and see if that solves the problem.
2. My advice would be to do whatever it takes to run the stock carb with the YZ, as it has the best throttle response of any 125 I have ever owned, and I've owned plenty.  Stock jetting is a little rich on mine for my elevation and woods riding.  I found the best combination was the accessory needle (1/2 step leaner) with otherwise stock jetting, and an "8" (NGK BR8ES) heat range plug.  Leaner pilot and main jets ruined the initial throttle response.  I just put a "9" plug back in when I ride with the fancy boys on an MX track.
3. Wiseco piston at 32:1 works well.  I just replaced the current Wiseco piston at 95.5 hours (crazy, right), but it looks great.  Hours 93 to 95 on that piston included winning my class at a regional hare scramble.
4. The stock suspension, after being sprung for my weight, was atrocious on eastern single track. I had an off - road revalve done (SoPro in Tennessee) and now it is sweet!  Best money you can spend in my opinion.
5. A Twin Air filter fits better in the airbox, giving you a little more room to operate.
6.  Budget for parts, and check the bike very carefully after each ride.  Maybe it's just my particular bike, but it seems like every time I ride it, I break something.  Water pump seals, cable guides, pipe springs and mounts, spokes coming loose.  Nothing major, but this bike seems to break more little things than any bike I've owned in recent memory.
7. If you change the gearing, confirm with lap times.  The conventional wisdom is to "gear down" but I actually found my lap times were faster with stock gearing on single track, screaming the snot out of the bike in first gear a lot.  I guess it just depends on local conditions.
8. Repack all bearings.  The yamaha factory must have a grease shortage.
Enjoy the new ride!
Edited by rpt50
No it's not a grease shortage it's about shipping rules so they use assembly lube. Part of the dealer setup fee for a new bike is supposed to have the bearings greased after they receive the bike. But 99% of buyers don't do anything about it and the dealer hoses you and pockets that fee.
  • Similar Content
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
    • By Randomneewb
      Hey guys, I have a 2003 cr125 I bought a couple weeks ago and I'm having a problem with it. The spark plugs die every about 15 minutes, with hotter plugs it will last about 45 minutes. I herd that if the timing is off it can over heat the plugs and burn out the the resistor. Is there any truth to that? The reason I thinks it's not fouling is because when the plug dies it gives no spark no matter how much you clean it, And it shorts out.
    • By fiat2nv
      Hi all, First post here. I need some help.
      Ive just bought an 05 yz 125 for a good price but it needs some work. One of the forks has some pretty severe pitting of the chrome on the stanchion towards the bottom near the brake caliper mount.
      Ive found a pair of good condition forks from an 04 yz250 for a very good price, from the research ive done its seems that both the 04 & 05 forks are 48mm but are different, with the 05 fork regarded as being better than the 04, but not as good as the 06 + sss forks.
      Im looking for the cheapest way to get me riding, Will I be able to make the 04 forks work with my 05 triple clamps, brakes, wheel, axle, spacers etc? If not does anyone know what hardware id need to make it work?
      Finally, as a last resort, does anyone know if i could swap the stanchion from the 04 fork into my 05 forks?
      Thanks, Andrew
    • By idratherberiding
      I bought a 2006 YZ250, have ridden it 5 times.  It needs some tuning, but I am not sure I'm keeping it so don't want to spend much on it.
      Has fmf gnarly expansion chamber and turbine core silencer.
      I ride about 1000 feet above sea level.
      I'm going to clean the carb and check the jetting.  What is a good jetting for me?  85 main jet?
      Also check the reeds.  Is there a big difference between getting aftermarket reed cage and reeds or just getting a cheap aftermarket set of reeds that fit the stock cage ie.  Boyesen Power Reeds?
      The other things I'm going to do is permatex all the joints in the exhaust system and a compression test.   It was 220psi 5 rides ago so I'm guessing itll be fine.  Its bogging a bit but I'm thinking its carb and definitely exhaust joint related.
      Let me know if I'm overlooking anything that could make the bike run crisper and more bottom end without throwing much money on parts
