2002 cr 125 antifreeze in the cylinder
Hoping to confirm my solutions here so my bike runs great has a new cylinder,piston and gasket set. I'm getting antifreeze in the cylinder for sure. So the head gasket, base gasket and water pump seal is where the problem is????? I know it could be cracked somewhere or something but I need to figure out where it's coming from should I replace the base gasket, head gasket and water pump seals?
I would, only cost's a few $ for the gaskets.
when you do them make sure all the old stuff is off.
So did I miss anything? Is there a way to check one or the other?
unless its leaking on the outside also there is no real way to know without tearing into it.
I had the same issue with my 450 turns out aftermarket gaskets don't seal as well and they'll leak
Or you didn't torque it right
Why is it always somethjng lol. I torqued it.
are they original stock gaskets or aftermarket
They were aftermarket
just go with Honda OEM parts there more expensive but last longer and work better
So I found the problem it was the head gasket. Replaced it with a cometic head gasket and torqued to 20 ft pounds, going riding sunday will see how it does
Cometic was the gasket brand that failed on me
I used cometic on my 05 Drz sm 434cc with success so I just went with it. I've always heard cometic was top of the line. It took maybe 45 minutes to swap it out so if it goes again.
