where to get this part?
so what I need is the square peice of metal that the rear axle goes through and it's the peice that you can move forward amd back to adjust the chain. I'm not sure what its called so I haven't been successful on finding it. I also need a nut to hold it on. not sure where to get either. 1995 yz250 thanks
I'm not home but I can post a picture if y'all need
later
4JX-25388-00-00 PULLER,CHAIN. Learn your way around a parts fiche and youll find anything you need
I think you're looking for the axel blocks. Any parts store has a diagram that you can look and see any part you need.
axle blocks are it I believe. should most be compatible with many bikes?
Look at aftermarket options as they can be cheaper...
They are generally bike specific so get the ones for your bike.
Used ebay parts are going to be the cheapest. Besides, to my knowledge axle blocks aren't considered a "wear" item. So a used part will do you just fine as long as your not doing a full resto.
k thx buddies
