1985 xr350r
I have checked all wiring put new pickup,coil,stater, and cdi box on it still nothing
Check your ground, check, just not look.
Bad ground, almost has to be if you did all that, unless you bought used parts and they were bad too.
Lol cjjeepercreeper, you beat me to it!
Edited by psychobeagle12
How many ground should that bike have buy chance. I got and the ole boy I got it from already had his hands in it and didn't know much about what he was doing
Your best bet is to google a wiring diagram for the bike and see. I have no clue tbh.
Edit: Do a google images search, take a look at the first thing that pops up for 1985 xr350r wiring diagram.
Did you check your kill switch by un grounding it from the handlebar?   also inside the sparkplug cap is a resistor that sometimes goes open.  Stick a flat blade in the cap and you can unscrew it's holder,
OK I have power going in to the cdi box and power coming out but when I plug the wiring harness back in to the cdi I box it has no power coming out
Clean all connections again and use die-electric grease. Saves a lot of headaches later. Also redo every ground connection. You can damage parts with bad connections.
Honda always has a central ground point on the frame, early XRs usually had it at the coil mounting bolt. To provide better electrical connection and seal for corrosion protection I solder all crimp connection.
And you kill switch should have two wires, the Blk/w from the CDI and a green one going back to the frame ground at the coil.
Brandon Comfort
I just checked ebay, Punch in 1985 Honda XR350R. I found a R&L side panel covers Their off '83&'84 models but look to me like a fit check these out. I know you can buy the yellow decal that fits in center, plus any grommets and bolts or hardware.
Brandon Comfort:
Back in '85 I rode one of these 350's from one end of the Baja to the other and back again No problems except the head light vibrated all to heck, wore the rear tire slap out. Still ride one today! Find most my parts on ebay or at cheap cycle parts.com
