Lube a new bladder ?
should i lube a bladder to help put it on the cap ? or is that a no no  ???
It will lube itself as you pushbutton down and the oil overflows
I think he is asking about just getting it onto the reservoir cap.
Absolutely
A smear of seal grease around the inner sealing lip will not only assist in installing the bladder but it will help to ensure the seal when gassing.
Terry
Absolutely
Terry
Is it a must? Cause I forgot to grease the bladder. :banghead: And what kind of grease would you recommend?
Edited by sTAb66
i will use some slickoleum
No you don't have to
but can i without ill effects ?
If it helps, one of my bikes (not sure CR125 or CR250) bladders was greased when I disassembled it (some kind of white seal grease). But I dropped it to the ground and was forced to wipe that grease off cause it was dirty. Never reapplied it and works fine, but I'll grease it the next time I rebuild the shock.
Edited by sTAb66
I have done a few shocks and never put grease on the inside of the reservoir. I can't say I noticed any problems.
As I said the oil will lubricate the bladder lip ,it really cannot matter if it's not ripping the lip on the bladder (very unlikely ) or the bladder doesn't seal (never seen it personally ) over thinking is going on here
I think he is talking about the inner lip, not the outer...where it mounts to the cap, not where the cap and bladder assembly mount into the shock.
Ah i see ,still not a worry ,grease is best but no grease is ok
