Will my factory 650L Stator power these?
Anybody ever try to run some cree LED lights on a stock stator? I don't think they draw too much power, but was thinking of some cheapo 2x2 ones from ebay. Thoughts?
Edited by RABBIDCOW55
could not tell exactly which light you were wanting but typically if you are replacing the main head lamp you are safe as almost any LED
of the same lumens as a Quarts or other conventional light will draw much less power (Watts). If you are using it as supplemental light, adding 30 or 40 watts
should not be a problem as long as you already don't have another power accessory such as heated grips or clothing.
