Extra connector behind headlight
In the wiring nest behind the headlight, I have a loose open wire, its like a female Bullet connector, its white with a black tracer. It has no mate, any idea what its for, I didn't test for voltage output or anything?
I guess you don't want us to know what bike you own, for some reason.
2015 exc500
They got rid of the wiring diagrams in the owner's manual now.
That sucks
Edited by Betarocker
Okay so this extra female bullet connector behind the healight is Hot (12v) with ignition on. I have to assume its for some accessory, what do you think it could be, its only a hot wire no ground?
Edited by Spud786
Fan power?
I already have a radiator fan
I also have it on my 14 350 EXC-F
Bingo!!
that looks like the ticket
I looked over the schematics in the repair manual, and i couldn't see any open wires.
It sure looks like a 12V power tap to me, though...
Is it fused?
Im sure its fused, the kill switch has to be on, including the key before it works
Being that it is only a single connector, it is intended for something that needs a separate chassis ground. Maybe it was for a European model that has different lighting regulations.
Is it the connector for the lower light on the headlamp?  The harness drawing makes it look like that connector is a short one that comes off of the main light harness.
No, that isn't it either.  That appears to be two wires...
I have the wire on my 2016. Anyone find out what its for?
It's just an extra hot wire for , hand warmers, GPS power, or anything else you would want to power up.
