CRF 80 Head Work
I have a 04 CRF 80, that needs new valves. Can anybody recommend a reputable machine?
Thanks.
Get a set of stainles Kibblewhite valves. Even on ebay. Problem solved
I still need a machine shop to grind the valve seats and assemble the head. Just replacing the valves, does not solve the problem.
Most any bike machine shop can do a valvejob and assemble. These are easy to do. 1 hour to disassemble, valvejob and reassemble.
teamrude
I have asked a similar question today but to expand on this thread..
 what valves should I use? I am not going hi performance, if anything I am interested in the most economical solution.  Are Kibblewhite valves necessary? another solution? I have read also, that the honda guides should be used,  any advice would be great.  also, if anyone can suggest a shop  in the northeast or I guess anywhere, if I have to mail it anyway, I would rather it go to someone that specializes in xr if it makes a difference.
thanks -j
ps. do most shops supply/source guides/valves etc, or as a customer do you normally supply parts to rebuild.
thanks -j
Good luck getting an answer here! No traffic! Try posting this in the lounge, where it should be and you'll get called out by the mod po po!
