new intake valves not having clearance.
Hi all this is the first time i have used thumper talk and my crf450 is my first big bore bike i have pulled down.
i have a 2005 crf450 and when i bought it last year i checked my valve clearance and it was down to .035mm and the shim was 1.8mm on L intake and .10mm clearance on the R intake with a shim 1.9mm and the intake valves had a definate wear strip all the way around so i replaced all valves with stainless steel valves and new springs and retainers.when i put it back together i put my old shims back in to get a reading to know what shim i need to replace it with and the clearance reading was the same as when i had my old valves in.i am lost. is it my valve seats that are worn?
Yeah .. You need to recondition the Valve Seats along with the new valves etc .
Valves need to be tipped.
thanks for the reply but im not sure what tipping me valves means?
i was afraid it would be my valve seats.
looks like im stripping it down again.:(
With worn seats (or better, recut ones), the valves sit slightly deeper in the head. Tipping is machining a tiny bit (to compensate for the worn/cut seat) off of the top of the valve stem.
hell yea that sound like a plan.my seats still have plenty of thickness left. thanks heaps for that post.
If you need help Please feel free to give me a call. We can tip those valves for you as well. (661)256-7309
