xr 70 not running well
i have an xr 70 that i put a new big bore kit but after installation it only starts on choke and backfires constantly. the bike runs for a few seconds then dies. while trying to start it the bike made a popping sound and spit smoke from the air filter. someone please help!!
Timing is off.
how do i change the timing becuae i checked all the marks and everything lnes up correctly??
First thing to check is your valve clearances.  If that's not it, I'm thinking you might be a tooth off on your cam chain and sprockets but it's been ages since I have performed that check or timed a machine like this so I'll let the rest of the community guide you on this.   Good luck, I'm sure it's a minor issue.  See if you can get hold of a service manual, that will guide you.
Greg
Edited by HondaRacer37
