2001 RM125 crank question
Recently the connecting rod bearing on the crank failed and there are heat marks on the crank next to the bearing. Also time for a new piston. The question is, should I reuse the crank and change the bearing or get a replacement crank? eBay has a complete rebuild kit with seals, crank, bearings, piston for about $260 delivered. Wiseco crank and Namura piston. Thoughts? Thanks.
Anybody? Bueller?
Don't go near the wiseco cranks. If you go after market get the HotRods crank kit.
If money is not a big issue, then use OEM.  If money is a concern, use HotRods crank kit as mentioned above.
