Identify these XR400 electrical components
I recently bought a used 1996 XR400 in pretty good shape.  It does have some electrical issues so I've started looking at the wiring. Can you guys identify these two components?
I'm guessing the larger gray one is a DC regulator/rectifier. Does anyone know who makes it? I'm not sure what the smaller Minks Electronics box is -- I can't find much information on Minks.
Thanks guys,
Pics 3 & 4 look like a rectifier, the first two look aftermarket.
Get a wiring diagam and match wire colours to your harness and you may get some insight on what a PO did to the bike.
Image 1 of 4 is a battery (left) and a non-stock part.  Since you have a battery, you probably have a street legal kit so I suspect that the item on the right side of image 1 of 4 is a flasher relay perhaps?
Image 2 of 4 is also non-stock.  It looks like a it might be a voltage regulator.
Image 3 of 4 looks like the stock rectifier.
Image 4 of 4 is a mystery.  I could not find those part numbers with a quick Google search
I recently got an XR400 that had a half-baked street legal kit with loads of dead-end wiring and nothing worked right so your photos look painfully familiar.  I started the bike up and began unplugging and removing one component at a time until the bike stopped running.  Once I stripped the bike down to its essential wiring/electrical components, it was much easier to match my bike's wiring to the factory wiring diagram.
You can then rebuild your electrical system (preferably with new, known-good, components).
Edited by ADHDJeff
Hey Chuck, thanks for the reply.  Pics 3 and 4 definitely match the wire colors of some regulator/rectifiers.  Pics 1 and 2 also match wire colors of some regulator/rectifiers like these Polaris ones.
I've cross referenced the Minks box with Polaris and came across this
Maybe one of the two is a DC regulato/rectifier and the other is an AC regulator?
Thanks for the reply, Jeff. I am tossing around the idea of completely redoing the electrical. Trying to reverse engineer what some dude did in his back yard 10 years ago is a pain.
Didn't the XR400 come stock with just an AC regulator? No rectifier?
Edited by XR4Ryder
After excercising all of my Google Kung Fu, I came across this
So, the Minks Electronics module in pictures 1 and 2 is just a switch for the battery. It senses engine RPM from the stator and switches the battery output (through the switch) on when the engine is running and off when the engine isn't running.
Sounds like it performs just the switching function of all in one modules like this
Edited by XR4Ryder
They don't look like XR400 electrical components.
Hey Rambler. Yeah, they're definitely not something I've come across while searching the web for XR400 regulators and rectifiers.
Do you guys recommend the Trail Tech Regulator/Rectifier for the XR400?
Shindengen makes the stock reg/recs for Honda and most other brands.  Use solder instead of crimp connectors.
Stock system has on pair of stator leads powering ignition and other pair to a finned ac regulator that so
Supplies ac regulated power to head and tail light
No rectifier on stock system
The better Baja designs unit has a a stator with 3 sets of outputs
Ignition just like stock
2nd pair to stock regulator to power head light only with a DC controlled relay to switch high vs low beam
3rd pair to add on regulator/rectifier and nicad battery's or capacitor for ballast all to supply DC regulated for all the other lights and horn
I ordered a Trail Tech R/R and am just going to go purely DC for now.  If in the future I upgrade the stator I may do an AC/DC setup.
I don't think you can run the CDI with DC.
I think the stock stator has two pairs of wires. One pair feeds the ignition system and the other pair fed the lighting system. I'll just use the second pair to feed my DC regulator/rectifier and the other pair will still feed the CDI.
I kind of misspoke. It won't be purely DC. The ignition will still be AC.  Only my lights and other accessories will be DC.
Edited by XR4Ryder
Digger is correct, there is no rectifier on a stock XR so image 3 of 4 looks like the stock rectifier regulator.
It's definitely not worth trying to figure out somebody's hair-ball wiring job.  The speaker-wire that was used by the PO on my bike, destroyed any confidence I had that it was done right--so I started over.  I'm very glad I did.
I bought the Baja Designs kit.  A little pricy, but installation was a breeze and the quality of the components is reasonable.
Yeah that's what I was seeing on the wiring diagrams as well.  I don't think that's the stock regulator though. The stock reg.had a green, pink, yellow and white/yellow wires.  The regulator in pics 3 and 4 has yellow, yellow, black, and red.
Those Baja Designs kits look sweet! After looking at those kits, I'm 99% sure my bike has a Baja Designs kit installed. It looks like this kit
I might have to return the Trail Tech regulator and try to use the one in pics 3 and 4.
That's the same Baja Designs kit I put on my XR, but it has none of parts you show in your photos (and the battery is installed in the headlight assembly), so if you've got that BD kit (and not the older version of it), you might have a LOT of extra stuff on the bike that doesn't need to be there.
Start the bike up and unplug one thing at a time.  If you kill the bike, mark it as critical, plug it back in and move on to the next component.  If your bike is like mine, once you've tested every single connection, you'll have a mess of dead-ended cables and components you can safely remove.
If you do have the BD kit, the wiring is super simple:
 - One pair of wires from the stator to the headlight
 - One plug/harness from the headlight to the key
 - One plug/harness from the headlight to the tail-light/turn-signal assembly
 - One plug/harness from the headlight to the hydraulic brake sensor
That's it.
Hey Jeff,  I'm wondering if I have an older kit.  I'll take some more pictures of the bike's headlight, taillight, etc. today at break time.
What does your regulator/rectifier look like?
Do you run the stock stator with the Baja Designs kit?
EDIT: Here are the pictures.
Edited by XR4Ryder
My BD kit looks exactly like the one at it's 121301RD for "red").  All of the components (relays, flashers, regulator, rectifier are pre-mounted and pre-wired inside the headlight.
It looks more like this with some subtle differences and my kit came with the newer (compact switch assembly) and ignition key--not the one shown below:
I'm running it off a 200w 6 pole stator (1 pair of wires to the ignition, 1 to the BD kit and 1 to the heated grips).
So you are running ac to your heated grips
I run one pair to stock ignition wiring
One pair to baja kit regulator rectifier
One pair to stock frame mounted regulator then to headlight bulb only of baja designs kit
Correct--I'm running AC to the grips (through a regulator).
  • Similar Content
    • By Kev_XR
      If you own an XR250, many of these tips will apply, however, the carburator jet sizes will be different.
      It really helps others answer your questions.
      I will fix them as time allows.
      Until then the Search Feature and enter "kevin's xr400 mods".
      The results will bring up most of the links.
      Here are some frequently asked questions I have answered before.
      Which XR should I buy?
      The longer the straights, the taller the hills, the deeper the sand; the bigger XR you want. The tighter the trail, the smaller hills, firmer terrain; the smaller XR you want.
      The XR400 has a great motor that will pull you almost anywhere. You can be sloppy on a hill climb on an XR400, where you have to keep the 250 singing. The XR400 weight is most noticable when you drop it or try to stop it going down a long downhill. (Moooomentum!)
      The XR250 feels like a mtn bike compared to the XR400. My friend rode his XR250 for years before decided he needed more power. Even then you can add a 300 kit and get good power.
      If you were heading to ride fireroads in Baja, I'd tell you to get the 600/650.
      To the tight woods, get the 250.
      A lot of both, the 400.
      Dual-sporting? Go bigger for more freeway, but don't show up at the trailhead with too big of a bike.
      All of the XR's are great. Pick the one that fits your needs.
      Gordon's Mods for XR400 (Uncorking the bottle up performance)
      XR400 History
      The changes to the XR400 have been listed here several times. This list appears to be complete.
      In addition, HairyScary discusses how to tell if a part has been updated by the part number. Good tip!
      XR400 history
      Getting the Spark plug out
      It seems the MotionPro spark plug socket does not work on the XR400R, but works on the XR250R.
      There is an OEM tool kit being sold on eBay that seems to work.
      717448 XR400 oil change
      Here is a way to make changing the oil much cleaner.
      This tips is really handy if you have a skid plate.
      XR400 oil change
      XR400 FAQ by Paul Gortmaker
      Paul usually has very good info.
      Small bolts
      BE CAREFULL with the bolts on the oil filter cover!
      An oil covered bolt will not torque at the same rate as a dry bolt.
      The friction doesn't build up, the force simply builds until the threads strip.
      This is the reason many people strip out these bolts.
      Here is an execllent website on bolts, oil, and misc values.
      Did you ever wonder why a 8mm box wrench is half as long as a 18mm box wrench?
      It is shorter as most 8mm bolts cannot take very much torque.
      I highly recommend getting getting an 1/4" socket set.
      I bought the Craftsman set at Orchard (owned by Sears), which tends to sell them for less.
      What is the Snorkle?
      This place has a description and pic, it's easy after you pull the seat. I siliconed a piece of coarse screen (fiberglass) over mine to keep bugs and stuff out. - NORTEXT
      717439 XR400/250 Pre-Filter
      After pulling the snorkle, there is a big hole on the top of your XR400. My friend showed me this prefilter trick.
      767409 XR400 Engine Bog, Pilot jet, and the Fuel Screw
      On XR400's twisting the throttle from fully closed to wide open will cause the engine to "bog" or in some cases die.
      831305 Valve adjustment (Am I retarded...)
      Inspect and adjust valve clearance while the engine is cold (35C, 95F).
      Valve adjustment
      389095 bigger jets (Lists stock jet sizes.)
      96-97 XR400's were jetted assuming you would remove the intake and exhaust snorkel.
      98 and later XR's were jetted assuming you would leave them in.
      bigger jets
      739907 Cheap Tool for Setting the Fork Oil Height
      There are some really nice tools out there for doing this job.
      This tool costs $4.49 at Kragen.
      Cheap Tool
      392932 high altitude jetting
      There are two big factors for jetting, elevation and temperature.
      Allen screws for the XR400 carb
      This lists the screws you need to convert the XR400 carb to use allen screws.
      Allen screws
      Screws for the brake and clutch after removing the stock handguards
      TBD - There is a post with the shorter screw part numbers for after the stock handguards are removed. Use search.
      Very quick engine hop up
      This is a very minimal change that should take less than an hour.
      Most of that time is removing the float bowl (3 screws).
      If you decide to do the full "Gordon's Mods" later, you will need to replace the jets again.
      o Pull the intake snorkle.
      o Add a UniFilter.
      o Pilot jet to 55, main jet to 155. (Assuming sea level and moderate air temps.)
      Source: Motocross Action magazine.
      Quick engine hop up
      Gordon's mods
      Baja Designs Baja Baffle with 96' spark arrestor.
      Pull the intake snorkle, UniFilter, 60 pilot jet, 162 main jet.
      (Depending on altitude and temp.)
      What to add to a new XR400 or XR250?
      Acerbis wrap around style handguards (saves levers and bars as they don't dig in)
      Baja Designs skid plate (Made by Utah Sports Cycle)
      Acerbis fork/disc protector
      Grease headset and rear linkage
      Spend you money on the suspension, not a pipe!
      First get some stiffer fork springs (96-97, 98-99 years)
      Fork revalve (cost: 2 qts of oil & time)
      Shock revalve (cost: oil, nitrogen, shim stack, friend who knows shocks)
      Jetting for Altitude (XR400)
      Assuming at sea level and 68 degrees, you would use a 60 pilot and 162 main.
      At 5000 feet and 68 degrees.
      Jettting correction:
      Main 0.96 * 162 = 155 -> 155 main
      Pilot 0.92 * 60 = 50.6 -> 55 pilot
      Due to your elevation, you have less air and less fuel.
      Your bike will not behave the same as a bike at sealevel.
      First, check the fuel screw. If it does not affect the idle speed, you have the wrong one.
      kevin's xr400 mods
    • By Child
      Can we make a sticky thread of pictures? I've done search for pics but I want to see all sorts of bikes just for ideas on stuff without having to go through tons of threads. Not trying to sound whiny or anything, but I think it would be nice to do what they do in the CRF250X forums with a sticky thread of just pics, no comments or anything. Think we can get one of those rolling here?
    • By kawamatt2
      Ok guys, add one more to the list of riders attempting the USD fork swap to an XR frame. Quite a bit of research here on TT and ebay hunting brought me a pretty good deal on a set of forks, triples, and stem from a 00' CR 250.
      There are a few different options for adapting CR style forks to an XR. Bushings for upper and lower CR triples can be made to allow use of the stock XR stem. Specialty bearings can also be purchased to allow use of the stock CR stem in the XR neck. And finally what seems to be the most common; modification of the stock CR stem to allow use of XR sized bearings.
      I obviously chose to pursue the third option for a few reasons, the most prominent of which is serviceability. I wanted to keep as many wear items at possible as stock parts. This has two advantages; availability and price of replacement parts. $45 dollar a pop "specialty" thin section tapered bearings don't sound too appealing especially when being used on a 12 year old dirtbike.
      So now we can get to the meat of the issue; modification of the CR stem. I should begin by saying that i am NOT a draftsman. I've taken a few classes on engineering measurements but am far from an expert and probably only mildly proficient reverse modeling components. With that said, the first order of business was comparing an XR stem and bearings to a CR stem and bearings. Shown below.
      A little closer look at the XR setup.
      And the CR setup.
      Now to get out the calipers and model up the stock CR piece. I used a cheaper set of calipers and suspect their tolerance is +/- .01mm. Good enough for gov'ment work though! All dimensions in millimeters.
      Now to modify the CR stem to work with the XR bearings while remaining compatible with CR triple trees. There are a few things to say about why i did some things the way i did but most of the thoughts are included in the notes section of the drawing.
      With a resized stem we run into the problem of mounting the top triple clamp. The hole is too large for the stem. An insert bushing must be made to resize the hole in the clamp.
      Finally what the stem and bushing look like together.
      Last one. The difference in how the top triple clamp is located on the stem. The CR is equipped with a chamfer that provides a stop for the tree while the XR's triple appears to be limited only by the threads for the castle nut.
      So... would like to hear your opinions on the execution of the stem modification and bushing. I think having these drawings will make it simpler to have the modifications performed as opposed to asking the machinist to completely reverse engineer the part him/herself.
      And a final query: Anyone know the thread callout for the two threaded portion of a stock XR steering stem? My drawings show the outside diameter of the threaded portions and i have a cheap plastic pitch gauge that tells me a pitch of 1.0 but i am looking for something more concrete than what i have.
      Thanks for your thoughts and opinions.
    • By ATJ_Number_1
      I'm on strike 2 here but thankfully this isn't baseball.
      The reasoning and my history. If you haven't figured it out yet I've done a crap load of work on these motors over the last 7 years but they have had 4 wheels around them. In the EX world there are a lot of carburetor options and although many are great there's a cheap alternative that runs 95% as hard as the high dollar options, some even liking it better then aftermarket. When I joined up here in the 2 wheel club I was shocked that the only accepted option was $400 for a 36mm Mikuni Pumper that isn't any bigger then stock! That cheap alternative for the EX is an 04-05 trx450r carb. It's 42mm round slide Kiehin piston-valve with accelerator pump and a mildly modded 400 loves it with a surprisingly strong bottom end yet. Yes I said 42mm!
      So as I build my XR4 I already know that I'd be shooting myself in the foot if I settled on a 36mm carb because I like bigger bores and cams and this motor likes bigger carbs. Makes sense, it is 400cc. Don't get me wrong though, the Mikuni is a real nice pumper for a stock bike and would seem fine on a well modded machine too but this 4 stroke is like every other one in the world in regards to when you go big inside, you want to go bigger outside or you're missing out.
      Whether the info is appreciated or scoffed at I'll post up my findings one by one as I try to find viable alternatives. When I say viable I mean still being able to use the stock environment and not needing a ton of work. I'm sure collectively this is not a new idea to search for such a beast but I enjoy a good project and I like cheap alternatives when they produce results.
      Currently the "test bike" is a 2000 Xr400r, snorkel removed, Uni filter, stock engine, stock headpipe and a 4" supertrapp slip-on with 11 discs.
    • By XL100allnightlong
      Just wondering if there is any tricks to polishing the stock headers on an 02 xr 400 to bring back the original copper color? If not ceramic coating them sounds like an option?
