Intake Manifold boot cheaper aftermarket replacement options?
Hey guys,
I have a 2004 TTR225 and the intake boot between the carb and head is rubber rotted and causing a small air leak causing engine running issues.  I have siliconed it which lasted a while then it started messing up again, so I've tried some fuel resistant epoxy this time.  If that does not last, I will want to replace it.   I would have already replaced it if the factory part 2LN-13586-01-00 was not 50.00 which is ridiculous.
Anyone know of any aftermarket manifold boots that fit the TTR for much cheaper from anywhere?
It's a weird part on a not very popular bike. I can't say for sure, but I'm 99.99% sure there's no aftermarket for that. What I do, however, is type in the part number to google and ebay and see where I can find it the cheapest.
Here's a few that are cheaper than $50.
http://www.ebay.com/itm/Yamaha-2LN-13586-01-00-JOINT-CARBURETOR-1-/271320102147?hash=item3f2bf03503&vxp=mtr
http://www.amazon.com/Yamaha-2LN135860100-Carburetor-Joint/dp/B005CXL1TO
http://www.partzilla.com/parts/detail/yamaha/YP-2LN-13586-01-00.html
http://www.boats.net/parts/detail/yamaha/Y-2LN-13586-01-00.html
http://www.2wheelpros.com/oem-parts/yamaha-joint-carburetor-1-2ln-13586-01-00-part.html
