Need help with vapor install 2015 yz250fx
I installed a trail tech vapor today. I mounted the vapor on the left side bar. Everything worked well, except that the temp sensor harness is way too short. Can you just cut and splice those wires to extend it? The easiest place to mount the sensor in the hose appears to be the one on the right side radiator. Has anyone done one on an fx. If so is this where to mount the temp sensor?
