what does this nean
91 kx250
When you pop in gear the bike wants to die, clutch isn't disengaging properly, but when I go out and try to open it up, it doesn't pick up very well. Almost seems like it's dragging? When I tried adjusting the cable, both ways loose and tight the lever would do nothing, it literally had to be in one exact spot to get anything to happen, and it was disengaging right t the very end of level travel (hand open)
If it helps, this biie has one of the stiffest clutches I've ever used. And my kick start sometimes slips.
Edited by dbryce19
Like there was lots of room to adjustment on the cable, and the clutch disengaged when my hand was almost all the way open, naturally I would tighten the cable, but nope. Nothing. Loosen it, nothing.
what's worn out here?
I already had the clutch apart, gave the basket s light file, it's ok. Outer was good, I will need new discs that I know. But thay won't cause my problem will it?
and anyone that seen my last topic, disregard it. I've done slot more tinkering, research and testing. Needs a fresh start
Edited by dbryce19
Derp. Holy shit, is there suppose to be the ball st the end of the rod for the clutch in a 91? I dint remember seeing one, and I sure didn't put one in there.....
that will be my reason fir dragging,
That ball acts as a bearing for the pushrod. Make sure the pushrod is in good shape too. Since you have the clutch apart, take the fiber plates and put them in a tub of oil fully submerged and let them soak for a good while, then when you reassemble use plenty of oil on the steel and fiber plates. DO NOT DRY THE FIBERS AFTER THEY SOAK, TAKE THEM DIRECTLY FROM THE CONTAINER AND PLACE THEM IN THE BASKET. Check the clutch springs length too, they may be shot
Well good luck then.
I realized after going through an online manual there is no ball in this model.
I took everything apart, every bearing, spring, and gear are perfect. The only obvious problems were friction discs and.clearly old clutch cable. Hope to hell this fixes it.
Last question is what's the torque specs for clutch springs? Online is giving me mixed messages, 7 ftlbs?
It's usually not very much. 7 seems right. Usually they bottom out and then you just tighten them a little.
Got the bike running, clutch is perfect. Lots of power.
problem now is It won't idle, there is the bouyson reeds in there, and stock jetting (155 main, can't remember other) , reeds are good btw.
Seems like not a lot of power bottom end and really jumps into power band. I think I'm going to take the carb apart one nore time and tinker / measure things. Anything els I should look for/into?
Here's my plug after running through ll the gears wot then killing it. To me it looks pretty good, maybe a little heavy on the gas side . More of a darker color tan in person, and wet on the threads.
Edited by dbryce19
That jump can be caused by a rich pilot circuit, or a lean one. play with your air screw to see if you can feel a difference one way or the other, if it makes a difference then you know where to start.
The screws never really made a difference.
And the pilot jet is a 58 . I got the carb in pieces on my table. Going to buy a 55 and 52.
Rest of the carb is in good shape.
The screws defiantly made the power band feel different. That's dialed in and screams top end. The screws did nothing to idle. And I plan on Bush sacking the bike, so going leaner pilot won't hurt me.
Edited by dbryce19
check to make sure your idle adjustment works while its off. if you screw in, the slide should go up and vice versa. Yeah you probably need the leaner pilot.
The small pilot(55), and some other fine tuning and it's pretty good. Pings out lots quicker. Still does an odd hickup if I hold it 1/2 or 3/4 throttle. I did mix the gas at approx 36:1, when I mixed it, so next time ill go 40:1
Why the hell can't I figure out how to get the throttle cable out of the needle clip?.... Wtf
pull the spring up, then push down on the cable while holding the spring back (very tricky), and it should come right out. its a difficult thing to do and the first time is always the grand struggle, for that matter the 100th time is just an experienced struggle.
I left the spring as is. With a brand new 40:1 mixture. The jetting, and everything els the bike ran MINT. I give it 90% full capacity . A fresh rebuild and clean power valve it's 100%. But still it's a 91, and if I'm not carefully will walk out from under my ass every gear.
next is suspension, way to soft rear, and front forks leak.
Kind of in the dark here. I went 55 pilot, 155 main, measured the carb, played with the screws and dialed it in, took almost a full tank of gas to do so. The plug Is a solid golden Brown top to bottom, snaps into power band as it should, decent low end, idled and clutch perfect.
Edited by dbryce19
Kind of off topic, maybe? But I had to remove the spring from the idle screw to have any affect..... Maybe it's worn, whAt ever. It's good there is s touch of play in both clutch and throttle.
Did you check to see if it moved the slide up and down when it was off the bike like I previously posted?
Not to be a dick, or an &%$#@!, but it would be easier for us TTers to help you if would have a little more organization to your post. Tell us exactly what you did in order and all that. Don't jump around, it makes it difficult to keep in mind what has happened. It just helps us better help you and nonetheless the help will keep coming. there are people that are much worse but I know you are trying to learn.
  • Similar Content
    • By luke8500
      Hi all,
      I have a 2004 Kawasaki kx250 that died suddenly on me the other day. all i can get it to do is backfire every once in awhile. Tested the resistance and everything of the magneto and stator with a multi-meter and all is good.  Coil is new oem Kawasaki the reeds are brand new vforce and the top end and carb have been completely rebuilt.  key on crank is intact and all the timing marks are lined up. I hooked a timing light to it and spun the motor over really fast and found that it is sparking way to late.  The service manual says that it is supposed to fire 14 degrees before TDC but it is sparking way after TDC.  Im thinking its a fried CDI box since its the only thing i wasnt able to check.  Any help would be appreciated
    • By luke8500
      Hi all,
      I have a 2004 kx 250 2 stroke and it wont start.  it only backfires.  I was out riding it one day and came up to a stop so the bike was just idling and it started to try and die so i revved it up a few times then let it die and now it wont start back up.  It only pops or backfires when you kick it.  Its getting good spark and i just put a brand new plug and coil in it. I took the reeds apart and they look like they're brand new.  It was running great before so i dont know what happened.  Im thinking it could be a fuel problem even tho the plug is a little wet if you take it out after a bunch of kicking.  Any help would be greatly appreciated
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
