Can I swap a stator/ignition from an 86 yz125 to an 87 yz250
I am trying to find a stator or the coils for my 87 yz250 but that has proved challenging at any decent price. I am wondering if I swap all ignition components from an 86 yz125 to my 87 yz250 if that would work. I know they aren't the same part numbers but that's why I wonder about the entire system? I have tried eBay coils and they were so far out of spec that they had no chance of working. I also have tried a universal analog ignition from and that thing sucks. I can't get the bike to fire for more than two revelations and their support has been no help.
Any help that can get me a working setup would be much appreciated. Even if someone has tricks for this joke of an ignition kit to get it working would be great.
I can't find pictures but I could swear I saw some Honda stators that had the same shape coils and looked the same size, I'm open to anything.
Great thanks! I actually went through the entire ignition again and checked all connections and wired in a ground that was very solid and directly hooked to the motor. Fired right up so I think I'm good. Now I just need to figure out why the clutch won't fully engage
  • Similar Content
    • By Mikeybabbel
      Hey guys, I just picked up a running 03 yz125 a few weeks ago and upon tearing down the top end, I noticed the cylinder head looks a little beat up. Is it possible to just clean it up or am I better off just buying a new one? Thanks guys.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
