125 carb overflowing
My friend has a ttr125 and gasoline is constantly flowing through the overflow line how do I fix it? I've fixed a few carbs and my first guess we're the jets or the float is stuck but he said the float is working
Float is probably bent and floats too high. Cant think of much else that causes this. Could be a little dirt in bowl too.
when youre in there check the float seat as well, just deal with a similar issue on a 125
thanks!
 Probably NOT a bent / misadjusted float tang.
Most likely corrosion has set in on the float needle and the cavity it sits in
Remove and polish both
