Dot 3 or 4 brake fluid
I have a klx300 says either dot 3 or 4 brake fluid, which is better?? Also can they be mixed?
DO NOT mix them.  4 is better, less susceptible to heat.
Ok that's kinda what I was thinking, thxs!
Please... post in the model specific form you your bike. The moderating team has had to move several new threads of yours each day.
DOT 3 and DOT 4 fluids can be mixed without issue. All that will happen is the DOT 4 fluid characteristics will be diluted with the addition of the DOT 3. Both fluids are glycol based and will not react with each other.
The types you don't want to mix are DOT 3/4 with DOT 5 or 5.1. DOT 5/5.1 also don't mix.
DOT 5 is silicone based and doesn't absorb water like glycol, but aerates very easily. Can't remember what 5.1 is made from.
