Neutral light staying on while in gear?
This has happened to me twice in the past couple days . Neutral light would be on while cruising down the road in 5th gear. Then will go off and work as it should .
Is the sensor in the trans ? Outisde the case ?
Sensor is outside the case. Stock cluster or vapor?
Sensor (just a grounding switch) is inside the case.  It is accessible from outside.  Or the wire to the neutral switch could be grounding any place along its length.
Stock ! I'm gonna take a look into it more one of these days just didn't know which wire it was .
Could be just a bad connection or something! I thought my trans was about to be toast lmao .
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
