Bleeding Rear Brakes [Help!]
Hey Guys!
I received my new HEL Stainless Brake lines and am in the process of installing them.  I have the front installed and bled.  Everything went smooth!
However the rear is giving me trouble.
I have the new line installed, new crush washers, there are no visible leaks.  I cannot get them to bleed!  I used a syringe to push fluid from the bleeder to the master.  I cannot get any pressure on the foot pedal.  I tried putting the rear end up 3 stairs to try and get the caliper higher, still cannot get it.
Any tips, trick or advice that you can offer would greatly be appreciated!
Yeah back took a while... Take it for a short spin and work the rear brake the.n bleed again...
Thanks for the advice! Just started it up and ran it for a bit! She bled no problem after that!
