Pipe guard clamp/nut?
Does anyone know where I can buy these things by themselves? I see them sold with pipe guards but I have a one off exhaust and I just need the clamps or nuts to go with the clamps so I can get my local shop to fab up a heat shield for the exhaust.
Thanks
I would try an industrial supply shop.
Basically you need the band clamp that is big enough to go around the exhaust with the nut assembly or a nut assembly that fit's on the clamp. If you can get these, then you can get the correct bolt for the nut and mod the shield if you need to fit the bolt.
This might give you some idea's https://www.google.ca/search?q=band+clamps+with+nuts&biw=1140&bih=619&source=lnms&tbm=isch&sa=X&ved=0CAYQ_AUoAWoVChMIyefLkcicxwIVzjuICh1YcQKA
Otherwise I'm sure that someone else smarter than me here will have some alternatives
Edited by filterx
Thanks for the reply. I can find clamps no problem. It's trying to find a nut/standoff that goes with them that has been the problem. I found one at CRF's Only but they want $10 a piece for them which seems kind of crazy. I figured they would be more common but so far I have been proven wrong. lol
