Starting tricks
I bought a 2007 kx250f yesterday and the owner started it right up when it was cold. I used to have a cr85 which was very easy to start. Now I can't get the bike started does anyone have any tips on how to get them started?
Did you give it gas while trying to start it? If so you might have fouled the plug.
Yes I gave a little gas but I got it started twice
Got it started twice it's good now but a pain in the ass to get started
make sure you kickstart is at TDC, and give it a kick with out giving it gas. Also, make sure your choke is pulled out for cold starts.
have fun!
It doesn't start like a small 2 stroke. I give it a slow kick to get to tdc. Make sure there's fuel in the carb then give it a solid kick and it always starts 1st or second kick. Never give it gas. Sometimes when it's hot I give a little gas
you can either tilt it on its side to get gas into the carb or twist the throttle 3 times before you kick it.. works every time on my 250
If its a carb model do this .
Turn on fuel tap
Lean bike over till fuel runs out the carb overflow tube
Pull chock knob
turn throttle full open twice, quite fast
Dont touch the throttle and kick with full kicks , not fast short kicks.
Should start in 3 kicks , if not starting like this then check valve clearances.
Mine was a bitch to start until I found what works for me, based on what I had for jetting. I live at 1200' elevation, and I ride from my door to about 4000'.
I run a 40 pilot, fuel screw turned all the way in. Its lean yes, but I give it 5 cranks of the throttle, then she fires up, first kick. I pull on the choke, and let it warm up.
Its never more than a 1 or two kick bike now, and its never flooded on me.
If bike doesn't start after 4 kick there's something wrong with it and I will do the follow:
Did you check the spark plug? Check the carb is clean. Check the carb needle is on the right turn.
If you have Spark and fuel then you might check more in depth.
Good Luck.
  • Similar Content
    • By Tedstrom
      Alright so I just rebuilt my 2012 kx250f complete rebuild. I put the motor back in the bike get everything hooked up and ready to go it takes a few kicks at first (obviously) but after it starts it sat and idled just fine for a while then it stalled out. Tried to start it again wouldn't start I took the spark plug out of it it looked good I was dark and wet. I cleaned it then put the spark plug back in it it took a few kicks but started right back up again then after a while it stalled out again and now I can't get it to start again!? Any help would be greatly appreciated thank you guys and girls for reading and hopefully for the help!!!
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
