Bike keeps bogging out
I just bought a 2006 rm125, the first thing I noticed was that it idles low and if I don't blip the throttle it'll die out. I also noticed i had the lay the throttle on slowly for it accelerate smoothly without bogging
But I was just cruising around my neighborhood 4th gear maybe half throttle and it bogged out and wouldn't start. When I got it to start again it seemed to have no power at all and would stall after a minute or two.
I ended up taking the carb out and wasn't dirty, but I touched it up and made sure the jets were clear. I'm thinking it is a problem with the carb but everything seems to be in good condition. I was also wondering what the factory settings for carb are.
Also, according to the previous owner it has less than 4 hours on a top end rebuild.
Mid someone could help me out that would be great.
It's a two stroke for the track.
It has NO power below the power band, which is the last 2,000 rpms.
That motor has peak power only, not much else.
You cannot ride it like a trail bike or a four stroke
You must stay in the highest rpms at all times, and use the clutch to help get you there if you have to.
Adjust your air screw for highest idle, then raise or lower the idle with the idle screw
  • Similar Content
    • By Sammy_1101
      Hi Guys,
      So I recently bought a 1997 XR400. I've done some research into getting more power through some basic mods and rejetting the carbs. Though all of the ones I've found have been for post 98 XR400s so the stock carb set up is a lot different. Usually people are opening up the airbox, exhaust ect. ect. and Jetting their carbs up to 160/162 for mains around 60 ish (I think) for the pilot. However for the 97 model this is close to stock for the jets.
      So essentially what Im asking (Just to cut to the chase ) Has anyone got a 96/97 (maybe 98, not sure) XR400 and has done these similar mods, and what sort of jetting have to done as a result.
      Thanks in advanced, also its my first post so apologies if I havent done everything correctly.
    • By Jturn
      38MM Cast SmartCarb. Purchased a couple years ago for a yz250. Don't have the bike anymore, and it has been sitting around for about a year. Used, but in fine working condition. You can also purchase a different needle for different bikes, as well as rebuild kits from their website.
      Asking $250 shipped to continental United States. I can arrange other shipping options at the buyers expense.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By knotduke08
      I know this topic has been discussed in the past, but I have not found any options available for the new 2018 bikes. I live and work for a new Beta Dealer (Auburn Extreme Powersports) in California, and we are having a difficult time mapping the RR-S bikes for full FMF exhausts. We have tried contacting Beta Support several times for this issue to no avail, and we typically are given the runaround when transferring to techs and secretaries. From what we can gather, the FMF flash is designed for the RR bikes, but not the street-legal counterparts. Every time we try to install the FMF map onto an RR-S errors occur, and the programmer screen goes virtually blank. We have heard through the grapevine that some are using the RR maps on the RR-S with success, but we have yet to try it, even on our own bikes for fear that it will permanently erase or damage the CDI. Any and all help or suggestions regarding this topic would surely be appreciated! Thanks, Ben.
