Front wheel change help
What is this tool called and what size is it for the front and back because I need to change both tires out on a new chain and put in new brake pads ImageUploadedByThumper Talk1439307152.083759.jpgImageUploadedByThumper Talk1439307166.351947.jpgImageUploadedByThumper Talk1439307191.884884.jpg
And I'm not sure what size the nut is for the Axel nut I think it's a 21 mm or you can be careful with a cresent wrench. When you go to put the front tire on make sure you square up the forks. Search YouTube I'm sure there is a video on how to do it. Back tire use a cresent to loosen the rear tire as well I'm not sure what size socket fits that one either.
maybe you should get someone alittle more knowlegable to handle these tasks!
I just upgraded to some G-Force wheels, and now I'm having trouble with the rotor and front caliper. Is there a trick to getting the caliper to open up wide enough to fit the rotor in place so I can bolt up the front wheel?
Stick a flat head in between break pads and push to the right that's what I did then they opened up again. The reason this happened was because you hit the brake lever
please take the time to search You Tube so you can get frt. wheel aligned properly! Same goes for the rear !
Yeah I will that's what someone told me
