Aux Lighting, DIY Molle Tank Bags, and my Touring/Luggage Setup
In preparation of a 500 mile trip, I decided that I was in need of some luggage. After looking at setups on thumpertalk as well as adv, I figured I would at least need a tank bag of some sort, panniers of some variety, and a duffle/box for the top. So the search began... and the regular suspects floated to the top: Wolfman luggage, and giant loop. What I found very frustrating was the cost associated with their products, and for me it was downright prohibitive, especially with tank Bags. So, I made my own.
Materials required were $20 worth of webbing, Buckles and tensioners. Rigging things up was really very simple, and turned out to be extremely sturdy.  the side tank bags touch the handlebars, but do not interfere with hand position or turning radius of the bike.
and A few Molle Pouches I had Left over from a former life:
And Just a random Picture of a test run... the highest point in Mississippi!!
I did break down and purchase a set of the Wolfman E-12 bags, and it was money well spend.  The installation took a bit of fiddling with the buckles due to how they have the webbing routed, but in the end it is a very solid setup.  I was a bit surprised at how small they were, but that is no fault of the product, and more a personal perception of what I saw before buying. That said, I am glad that I did not go with the Daytripper bags, which was my second option.
After filling the E-12's it was clear I needed more space, and not wanting to carry a backpack, I pulled out my Plano gun case that I picked up at walmart a while back.  It has a decent amount of space without being gigantic on the back, and will take some of the more bulky things that did not really fit well in the bags.  (Disregard the mounting method of the fuel bottle... that is not how it will be mounted while riding)
And the end result:
All In all I am pretty happy with the loadout.  I should be able to carry everything I need for a weekend trip and some camping.
The other addition I did was to add some LED aux lights to the system.  Mounting them in a tucked away location was the biggest challenge... I did not want them to be sticking out all goofy like, and wanted them to be below the top of the headlight fairing.  Creating a mount took some creativity since my welder was not currently in my posession, or even within the same state.  So welding aside, I found that bending up some aluminum strap was sufficiently easy, and resulted in a fairly rigid solution.
For wiring, used a fused power lead, then spliced into the high-beam circuit to trigger a relay to power the lights.  That way I am not tapping more power from the headlight wiring, and have the aux lights on a separate fuse.
I may try and snap some shots of the light output difference if people are interested.
As always, comments/concerns are always appreciated.
Edited by dgrigorenko
How much weight are you planning on putting on the tail? If it's more than the 4.5kg specified you may want to think about bracing the subframe?
I am what many would call a "minimalist" camper... no tent, small stove limited water stores (but carry a pump to produce potable water anywhere)...if it all added up to 25lb I would be surprised.  I am not really worried about the subframe, especially since all my riding on this trip is going to be pavement.  also check out this thread: are people loading way more than I will be.  Just for the sake of due diligence, I will try and weight all my gear and see what I come out to.
Hopefully ok if all riding is on pavement. This complete break of the subframe was caused by a rotopak (less than 10kg with 1 U.S. Gallon of fuel). But it was discovered following trail riding.ImageUploadedByThumper Talk1439327956.138569.jpg
Nice YJ :thumbsup: :thumbsup: :thumbsup:
XJ actually... both have square headlights though Edited by dgrigorenko
Just weighed all the gear, and including box and bags it's 27.3 lbs. I forgot how much that plano box weighs... It's weighs 9 lbs empty... But all the gear in the Wolfman bags was 10. 3 and the box and goods was 17.0. But even at 27 lbs I am still not worried about frame failure from road riding, especially when I look at where the loads are and how they are distributed... A 10lb load at the farthest point of the fender can easily put more stress on the frame than a heavier load mounted inward... Especially when we are talking about a frame design that has a reducing section modulus. That in combination of full reversal fatigue when riding off road can cause problems.
I love your tank bag setup ....  :thumbsup:  nice job and the best I have seen thus far ... :prof:
When it comes to the rear sub frame durability ... I think it is all about how you ride and the abuse you impart upon it.
Some guys can wipe out the sub frame with 20lbs on it while others have no problem at all with 40lbs loaded up...  :excuseme:
Just being aware that it can be a problem, will help you avoid it ....  :thumbsup:
Most if not all of your lightweight dual sport bikes have a weak subframe when it comes to loading gear for adventure travels.
just my opinion and not to be confused with actual facts ....  :p
Good luck. It can always be braced and welded later.
What might help is if you can bring much of that weight onto the pillion
Well just to put this thread to bed... I finished the trip.... First thought after the fact.... Man was Google maps wrong about time. Gmaps said it would be about 10:30 road time, but it ended up being 14:35. I accept a margin of error, but 4 hours of unexpected seat time started to wear on me... Literally. Speaking if which I splurged on some fancy undies before rolling out: moto skiveez, adv version. Gotta say, they are fantastic! No chaffing, monkey butt, or any moisture issues, but most of all, it really stretched the amount of time it took for the butt burn to set in, and it was diminished at that. Money very well spent.
And here are more random pics.
Serious bugs once night fell in Indiana
And the ride home
All in all, great ride, luggage worked perfectly, the molle pouch was just the right size for what I needed quick access to. Next time I think I would ditch the box for some small duffels just to save weight.
Oh and I pulled the rear plastics... No Frame cracking or signs of excessive strain
  • Similar Content
    • By Ride Red 123
      Just wondering how many TTers there are in Texas.
    • By speedtoad
      I think honda let us down with the new CRF250L. We didn't need another Japanese softcore Dualsport option. Suspension looks good for street but not enough for serious off-road, and 320 lbs wet is way to much for a 250. This is basically a small trail bike just like the CRF230L.
      Looks like the motor is from the CBR250, tuned for better low end. Should last forever and at $4499 retail the price is low.
      I won't be trading it for my DRZ. I would consider the new NC700x for a commuting bike. I saw it at the motorcycle show. Its lockage 21 liter storage was a nice option.
    • By Nuts4CRF
      I just got my hands on a new CRF250L. Since this model was just released there are not yet model specific luggage options. Until some one comes out with mounting hardware for a set of hard panniers, what are my options? I tried a set of Ortlieb waterproof soft bags but the exhaust burned through the rear strap. The inside of the right bag was also hot as an oven. The obvious answer is a generic tail bag but I'd like more capacity and still be able to strap on a tent and sleeping bag. Would a pair of Aerostich tank panniers work? I'm concerned the flair of the front body work would push them out too far.
    • By Oldmossyspokes
      I've been reading many posts, some good, some bad on our new kid in town...the 2013 Honda CRF250L.
      It is my impression that most of the posts are from riders that either (a) don't have one or ( haven't rode one; this is not surprising since they are hard to get right now...the dealers can't keep them in stock. hmmm...pondering...can't keep them in stock.
      Yes, the supply is limited due to overseas demands for the little scooter..but still I think, "can't keep them in stock" says something to the market.
      I recently traded in my 230L on a DRZ400S and my wife traded her 230L in on the new CRF 250L. WHY? Because we wanted to give up some gas mileage for a bit more speed and better suspension...we got just that on both accounts.
      I took the 250L for a little spin down HWY 101 in Washington state...the hilly winding part along the Hood Canal and found this machine to be a breathe of fresh air over the 230L on the tarmac. It could easily keep my 235lb body going 65mph without waiver. It cornered well, handled well, was nice and quiet and achieved 70 mpg.
      Then we headed up into the Olympic mountains...the old logging roads and fire roads. The 250L kept right up with the DRZ and had stellar handling compared to its little brother the 230L.No issues of hitting bottom on either end...not exactly a tractor but that's what the shifter and clutch are for when the terrain goes south on you.
      Yes, your not going to win any enduro's on this nor astonish anybody on a track or load it down with 200lbs of gear and take off on a 2000 mile trek...but, that's not its purpose.
      Let's examine reality for a moment :
      Nobody ever has, nor ever will, make the perfect "Dual Sport" bike...this is a pipe dream conjured out of desperation and limited resources...or something related to that sort of mind freak in some way. If one wants to ride "anywhere" one needs at least three, if not four bikes.
      We to like to go on the trails but we take our WR250F and WR450F on the trails...that's what they were made for and they're great for that...but not so much on the roads because one just rides from gas station to gas station. (and needs ear plugs and a mouth piece to keep ones teeth from rattling out).
      We also like to ride on the highway...on a road bike preferably...nice smooth inline four like my old GS1000, or a Gold Wing, BMW or what have you...don't really care as long as its comfortable and fast.
      Next we have the adventure bike...The gentleman's "dual-sport"...sweet on the highway and fine on the dual track but too much work on the fire roads or trails. Enter the F800GS or similar orange bike.
      Finally, we get to the Dual Sport; part dirt bike, part adventure bike...good gas mileage, enough suspension for some rocks and logs, street legal and emissions correct. For the days one doesn't want to bother trailering the WR, but still may get into some crap a big bike can't handle without an expert rider at the helm. The 250L is fine for this...what we call "bike packing in the back country" walking by a large margin. Did I say fine? I mean the good kind of fine...not stellar...not a pig...just fine. Honda nailed that with a good price tag...not to much, not to little...just fine.
      Myself, at 6'5" and 235lbs, prefer the DRZ400S, but Ive been riding for 35 years and can deal with the high seat...frankly if not just from the size standpoint the DRZ is also...fine. Yes, Honda answered the desire of a whole lot of people, just like us, with the 250L...its a dual-sport and it serves that niche well. Its an improved 230L from our view and that's just what we wanted...just a bit more...not to much...just right.
      If one wants an orange bike...shut up and go buy one...they made them for those with your needs and wants. The 2013 Honda 250L is not for you and was never intended to be for you. Most recreational riders of average size, that have a job, will love this little dual sport on the county pavement and the logging roads...Thats where they ride when they say "Dual Sport".
      Good Job Honda ! Please make a CRF400L...I'll take two.
      I'll never understand those that need to hate something else in order to like what they want...twisted at best....good day.
    • By Bryan Bosch
      The Honda CRF250L is an all new bike and b/c it really didn't fit well with the other CRF's, we decide to give it its own forum and see how it goes. Meaning, if there is enough interest (discussion), we'll keep it like it is now. If there is not, we may elect to combine it with another more established forum, say the CRF150/230L forum until we think that there are enough owners for it to stand on its own.
      So, just a "heads up" to manage expectations going forward. Hopefully this forum will grow fast and become a great resource for its owners.
