third owner, trying to fix carb issues
So....2007 DRZ 400S. White Brothers E2 pipe, 3x3, and carb jetted with "some" kit. What I have elicited from my one month ownership:
-WB E2 with spark arrestor
-shitty 3x3 mod, but done
-modded stock mikuni carb, with hex heads, adjustable needle, and a 22.5 pilot.
My bike bogs A LOT off idle and up till max throttle, so here's what I found when I bought it:
-Checked to see what pipe was on it: It was a WB E2 with spark arrestor
-Checked to see if the airbox was modded: Yep; a shitty version of the 3x3 mod
-Pulled carb to see what's up: 22.5 pilot, "other than stock" main (I could not read the number)
-carb bowl screws replaced with allen bolts (That's an indicator)
-Adjustable needle set on "3"
Bike ran VERY lean and fuel-starved after about one minute at full throttle. Tons of backfiring off-throttle, HUGE "flat spot" mid-throttle, and the ability to run at full throttle like one minute before fuel starvation.
What I did today:
-Pulled the carb and cleaned out EVERYTHING.
-Verified that the previous owner had done a jet kit, but didn't do it right (allen-head bolts in bottom bowl)
-saw that there was a 2.25 pilot jet (not a 25)
-could not verify main jet size do to last owner buggering it up with a too-small flat-head screwdriver
-saw that the aftermarket needle was set on "3" from the top
-moved needle to "6" to richen up the mixture A LOT
-blew out ALL jets on the carb
What it does now:
-Has very-little bog when rolling on throttle
-still has that little bit of bog when rolling on which I attribute to not running a 2.5 pilot.
I live in Coolidge, AZ at 1600 feet MSL by the way.
Gimme a link to a place that I can buy ONLY a 25 pilot and ONLY the correct O-ring for my float.
Thanks in advance.
Edited by SkymonkeyONE
dont know, somebody may have an extra they can shoot to you .. if it was me i would get a jd jet kit, extended fuel screw, a rebuild kit,  and be done with it ..
is the infamous flat spot oring still in place at the top of the carb ?
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
