Is my clutch basket damaged?
ImageUploadedByThumper Talk1439329745.792175.jpghow can you tell? ImageUploadedByThumper Talk1439329803.439375.jpgwhen getting on the throttle the bike revs like normal but the bike doesn't go anywhere, it does move in every gear just towards the end is were it slips. Edited by MountAiryTrailRiders
That's just casting marks on the pressure plate, ignore them.  The wear surfaces to look at are the basket and inner hub.  Also check your plates and fibers for wear/warping.  From your first picture I do not see any wear on the basket which is typically the spot that wears first.  I cannot tell from your pictures if the hub has wear.
This link should help:  http://www.dirtrider.com/features/protips/141_0711_pro_secrets_clutch_inspection?image=0
ImageUploadedByThumper Talk1439335149.474429.jpgand the minimum is 13.5 for the lining discs so seems like I need new fibers and discs springs Edited by MountAiryTrailRiders
ImageUploadedByThumper Talk1439335498.763734.jpgImageUploadedByThumper Talk1439335514.840426.jpgnImageUploadedByThumper Talk1439335534.712579.jpg Edited by MountAiryTrailRiders
