float height PWK 38 on 125?
Does anyone know what the recommended float height for a PWK 38 airstriker is?
It´s installed on a 2002 125.
Pretty sure it's 16mm....
AS1 PWK =  Round screw on top, should have a float height of 16mm
AS2 PWK = Flatish rectangular top, held on by 2 screws. should have float height of 7mm
Thanks mate, I have the AS2. Is there an official manual for this?
Same float in both, as well as the PJ's... 16mm.. I think the TMX's are 7mm
^^^ This
^^^ This
Source please?
Source please?
For the bolt on cap short body carb like the '00-up Yamaha YZ250 or KTM 250SX, you will find the float level spec in the service manual at 6-8mm
For the screw on cap PWK carb like the '00 CR250 and aftermarket PWK, you will find the the spec in the service manual is 16mm.
You can't obtain a 16mm float level on a short body PWK if you tried.
Edited by CamP
Thanks for clarifying CamP.
