08 kx250f water pump seal change
So this Friday I will be changing out the seal which is behind the impeller in the water pump. The seal that is accessible from the outside. Now I've been told that the whole thing can be changed out from the outside without having to pull the outer crank case off. If any of you guys have done this before would you let me know how it went, what to do what not to do etc? Thank you very much.
