Wider seat for 13 XC-W 450?
The seat on my 13 XCW 450 is killing me after a couple of hrs. I have aready replaced it with a taller Sicas racing version but i really need something wider. Does anyone make an aftermarket seat that is wider and if i am lucky taller also??
I really like Seat Concepts.  It is way more comfortable than stock.  Just wide enough to be more comfy, but not sacrifice handling.
Another for Seat Concepts. They are wider and more comfortable than stock and they offer a tall version.
Might I ask what rear spring that you are running and settings?
I will need to check on the spring and settings. I am 6'5" and 265lbs so i had tech care here in michigan set up the suspension when i bought the bike 2 yrs ago. I mostly use the bike for single track and trail riding with my son and wear ktm padded riding shorts. I will contact seat concepts to see what they have to offer.
When I bought my EXC, the stock seat was WAY too hard so I bought the Seat Concepts that they had in stock.  I didnt realize at the time it was a tall model. It is waaaaay more comfy, and the back part is wider than the stock seat.  Mine is a tall, and I may sell it and get the standard height because I think the stock height will be better for me.  I highly recommend the seat concepts seats!
I'm 5'9 and the Seat Concepts standard is perfect for me.  Its softer, flatter and wider in just the right ways.
I rode a street bike yesterday (cbx500) and was complaining about a sore ass in 30 miles.  All my bikes will be getting this seat from now on.
Are you kidding????
Buy you some springs all ready.....
1 seat concepts
2 seat concepts
3 seat concepts
Got it?
Are you kidding????
If you must know, I posed the question cause his butt was hurting. :rolleyes:
The suspension can definitely make a seat feel better or worse, when sitting.
But he didn't know what he has, so moot point.
I already have new front and rear springs plus valving fron tech care when i first got the bike. I used to race street bike professionally so i know what a difference a proper suspension can make. It was a brand new bike that had the suspension done before i ever rode it.
Thanks for all the help. I ordered a seat concept seat yesterday afternoon. Hopefully this will make the difference. The Sicass racing seat would kill my rear end after a hr on plain dirt roads. I think the foam was to soft and i was bottoming out on the seat pan. Plus that seat is narrow and rounded at the top. Seemed to fit right in the crack of my rear end. Lol
  • Similar Content
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
    • By Brawg
      SO, for information sake and to power the search engines with some key words that i couldn't seem to trigger during my research...I'm posting my desmog process on my new 500exc. Being a new bike...i wanted to make sure that all of my "doings" were going to keep the short excuse for a warranty in tact. I have part numbers for the plugs, washers etc as well as what all came off of the bike. I know it's a simple process for some, not so for others and would like to give credit to the advrider.com writeup for some great info.
      Long story short...i plugged the hole left from the smog pump thingy on the right side of the cylinder, the Secondary Air System (SAS), the overflow canister, and all the hoses/wires that go with. The electrical plug that was involved I simply taped up with grease in it and strapped it to the inside of the frame rail.
      After i took all of it off, it would not idle....i turned up the idle adjuster (to the left) or counter clockwise in order to increase the idle speed.
      Result!!!!!! NO popping on decal, no stalling after hard accelerating, etc. Sometimes after much creeping and low rpm riding it will load up and flame out. I plan to try a different map after i install my exhaust. I think a new map will be able to add some rev to the top end. Right now it seems kind've flat once you pull through the sweet bottom and mid ranges. The bottom end power of this bike coupled with the silky smooth clutch action makes for the easiest and best suited off road bike i've ever been on. It does what i need it to do!
