Swap / compatibility Rear brake yz 125 and yz 250
Hi guys
I would like to konw if the rear brake (caliper+ bracket) is the same for the 250yz2003 and the 125yz2003 ?
The rear brake reference is different :
125 yz 2003: 5UN-2580W-10-00
Same ref on : yz 125 2004 / 250 wrf 2004 / 450 wrf 2004
250 yz 2003 : 5UN-2580W-20-00
Same ref on : yz 250 2004 / 250 wrf 2003 / 450 wrf 2003
But the rear wheel and the rear arm are the same on the 125/250 yz 2003
Thanks for your help
Hmm. This is a tough one. The "-10-" in the part number usually means a subtle change; a difference in paint or finish, or a revision bump. Perhaps the pad material is different between the two?
The fact that the "5UN-2580W-" numbers match gives the strongest credibility that the two parts will interchange. Sorry, that's the best I have.
BTW, brilliant bit of investigative work! Well done.
