Transmission issue
G'day guys. Recently bought my first Kawasaki kx250f . I have owned bikes in the past but decided to go green. Anyway it was having the problem of not selecting 3,4 or 5th gear. Having dealed with this kind of thing before I got it and now am a little puzzled.
I removed the shift shaft and tried shifting straight from the drum. The problem persisted . So thinking it was the shift forks as the only logical explanation as everything else was removed and it still wouldn't shift I split the cases. What I found was weird. As soon as the jmcases were split I took the gears out and inspected . Then I put them back in and tried shifting through the gears and it went through all the gears fine. The forks weren't damaged or worn . Why would it not shift from the drum then as soon as its split shift fine?
And it's an 06 . Thanks guys
  • Similar Content
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By MotocrossMaverick
      Hey guys i have just gotten off my Honda crf150r and i am looking for a new bike. I have been to the dealership and have already checked out the Kx250f and the Crf250r. I am looking more at the Rm-z250 then any other bike right now. I need help finding what bike would be best for me. I have never been on a 250 but i am starting racing about a month after getting the bike. I was also offered $5800 for the Kx250f and i know it killed 2012 i am just not sure about a Kawasaki. Honestly i am not sure bout any please help!!
