'13+ REAR WHEEL OFFSET ADAPTER
I'm starting to look for the best way to solve my hub offset ordeal on my '13 450, so I can use my older spare rim.. I,be seen on crfstuff.com have made a run of offset sprockets, and this would more than be fine for what I need, but they are out of stock with the number of teeth I would like to use..
Has anybody used an adapter with good results, or has made something before?
Does anyone know if any other bike manufacturer has the same bolt circle pattern with a larger than Honda sprocket bore diameter to accept an adapter made from a stock Honda sprocket?
