jase12 Posted November 1, 2015 Alright guys so here is a puzzle for you, I have a 2013 250 sxf that recently had the motor pulled for a rebuild. That's all finished and I've got everything hooked back up. I go to start it with the electric start and it turns over once than just clicks. So I was thinking I blew a fuse on the solenoid, but upon checking, I hadn't. I replaced them anyways same thing. Click. I meter tested the battery to solenoid. That's good its getting power, then I tested the other end of the solenoid. Good puts power through. And I am getting power also all the way down to the starter terminal. But, like before she just clicks.... I am stumped, is the started stuck from sitting or what? It would be nice to hear every ones thoughts thanks!! Share this post Link to post Share on other sites
KRAYNIAL My Rides (5) Posted November 2, 2015 You can't test a battery for strength with a multi meter. You need to charge or replace your battery. Share this post Link to post Share on other sites
