defiantk Posted November 1, 2015 Been trying to powder coat the a arms off of my 85 Lt230S suzuki and im not sure about the bushings/bearings(?) inside the arms. I plan on masking off the inside on the arms anyways but do these need to be removed? Can they take *400f necessary to powder coating? Are they all metal or what? I tried removing them but for the life of me can't Share this post Link to post Share on other sites
dfesmire99 Posted November 3, 2015 (edited) Been trying to powder coat the a arms off of my 85 Lt230S suzuki and im not sure about the bushings/bearings(?) inside the arms. I plan on masking off the inside on the arms anyways but do these need to be removed? Can they take *400f necessary to powder coating? Are they all metal or what? I tried removing them but for the life of me can't 📎image.jpg Those bushings/bearing are probably press fit from the factory. The replacement parts fiche shows a replaceable bushing/bearing, so you can get them out but you'll need a press.Take a look @ the "suspension arm". https://www.rockymountainatvmc.com/oem-schematic/2 Edited November 3, 2015 by dfesmire99 Share this post Link to post Share on other sites
defiantk Posted November 3, 2015 Thank you, I'm definitely not going to be taking them anywhere to get them pressed out. Anyone know if they can just take the heat or not? Share this post Link to post Share on other sites
defiantk Posted November 18, 2015 Does anyone know this? Must be some way to do this Share this post Link to post Share on other sites
