JFoVStar650 Posted November 2, 2015 Returned form Crested Butte, CO a couple months ago. Bike ran great, no issues changing elevation from sea level to 10,000ft. Now that i'm back in Texas, the bike won't run. It will start up but is idling very rough and then dies. I gave it enough throttle to keep it idling for a while, thinking the computer would adjust to the elevation, but no luck. I took it around the block and it's rough and very low on power. I've disconnected the battery (again, thinking it would reset computer) and drained the gas and filled with fresh gas. Still no luck. Any suggestions? Tried to post video of the rough idling but no luck there. It will idle rough for a few seconds, pop, spit, chug, pop, then die. Again, bike ran great in CO all the way through our last day of riding. Haven't changed anything since getting back to TX. Share this post Link to post Share on other sites
weantright Posted November 2, 2015 Change the fuel filter??? Share this post Link to post Share on other sites
JFoVStar650 Posted November 2, 2015 Change the fuel filter??? Negative. Will try that this evening and make sure the TPS isn't loose. Share this post Link to post Share on other sites
1 lunger Posted November 2, 2015 Check battery connections, tps, and for bad gas. Share this post Link to post Share on other sites
JFoVStar650 Posted November 2, 2015 Check battery connections, tps, and for bad gas. Checked those today. Good Anti-Gravity battery and connections are good. Will check TPS again since i adjusted it when i first bought the bike, and fuel is fresh 93 octane. Share this post Link to post Share on other sites
1 lunger Posted November 2, 2015 Those battery's can fail. I'd double check it! Did you wash the bike when you got home? Check fuses and spark plug wire. Share this post Link to post Share on other sites
SquidZip Posted November 3, 2015 Semi-plugged injector, maybe?? Share this post Link to post Share on other sites
JFoVStar650 Posted November 3, 2015 (edited) Those battery's can fail. I'd double check it! Did you wash the bike when you got home? Check fuses and spark plug wire. Double-checked battery, she's good. I did wash the bike when i got home. I'll move into the fuses, connections, and plug wire while the new fuel filters on shipping (filter looked clean). Semi-plugged injector, maybe?? Acts like a fuel problem or electrical. Hopefully not an injector. Filter looked good. Edited November 3, 2015 by JFoVStar650 Share this post Link to post Share on other sites
weantright Posted November 3, 2015 We had a CPS go bad and when it did it acted like it ran out of gas and never started. This is something a dealer tool can check or you by using a volt meter from what I was told. Share this post Link to post Share on other sites
JFoVStar650 Posted November 6, 2015 So i replaced the fuel filter ("old" one looked perfect, but replaced it just in case). No change. Also checked the battery. Getting a good 13.3v at battery. Also left it on the trickle-charge for a couple days just to eliminate the battery. No change. Below are the things i have checked or changed so far: Drained gas and added fresh 93 octane Replaced fuel filter Check battery (13.3v) / charged just in case Checked electrical connections for anything that may have become disconnected or loose Checked TPS for looseness Played with choke / idle Disconnected battery in hope things would (reset) Suggestion on where to go from here? It still sounds to me like the timing or something electrical is off. It will fire up but will chug, pop, poop, spit, bang, spit, chug, and then die. The only thing that has changed since i rode it in CO is the trip back, a wash, and it fell over while washing. It was running great before i left for CO and while in CO. Yes the exhaust plug is removed haha. Anyone know how to check the cam sensor? Share this post Link to post Share on other sites
weantright Posted November 6, 2015 First use your multi meter and check to see if there is a short by using the ground and one wire. If it reads "0" there's a short. Some CPS have a "good" reading but I don't know if or what KTM is. Going by memory our CPS was like $20-25, hate to throw money around but's it cheap to replace. Dealer cost total for job including new oil filter was $300. Share this post Link to post Share on other sites
JFoVStar650 Posted November 6, 2015 Anyone have schematic of the CPS or a pic or where it's located? Unable to pull up anything right now. Share this post Link to post Share on other sites
weantright Posted November 6, 2015 Ignition side behind the stator. At least thats what my dealer said. Share this post Link to post Share on other sites
JFoVStar650 Posted November 7, 2015 I'm assuming the crank sensor has the red and green wires running to it. Remove the two bolts and measure the voltage and ohm it out? I;m out of ideas after that. If it still thinks it's at high altitude, is there a proper way to reset things?? It seems either very very lean or timing. So I will try to check the crank sensor, but note sure how to check the injector for blockage? Share this post Link to post Share on other sites
JFoVStar650 Posted November 7, 2015 Apparently that's the ignition pulsar coil, not a crank sensor. Not getting any help from the manual. Share this post Link to post Share on other sites
weantright Posted November 7, 2015 I believe it was Slaven who had a injector cleaner device that will not only clean (as much as carb cleaner can) but chech for operation. This isa cheap tool. Share this post Link to post Share on other sites
JFoVStar650 Posted November 8, 2015 I believe it was Slaven who had a injector cleaner device that will not only clean (as much as carb cleaner can) but chech for operation. This isa cheap tool. Thanks for the info on the tool, I'm ordering it. After changing the air filter I found some debris in the intake, so odds are the injector has something in it. I'm not too crazy about the way the air filter gets secured. Doesn't seem supportive enough to make a good seal. Going to play around with it and find a way to make it seal better. Share this post Link to post Share on other sites
weantright Posted November 8, 2015 No way intake dirt clogged the injector. When installing the air filter watch the lower outside edge of filter. If not perfect this edge will pull away from sealing surface. This design is a PITA however better then the Beta I had. The best is my Sherco or the Italian Husqvarna, almost circular and sturdy sealing edge. Share this post Link to post Share on other sites
JFoVStar650 Posted November 8, 2015 (edited) No way intake dirt clogged the injector. When installing the air filter watch the lower outside edge of filter. If not perfect this edge will pull away from sealing surface. This design is a PITA however better then the Beta I had. The best is my Sherco or the Italian Husqvarna, almost circular and sturdy sealing edge. Ahh. You're right about how it wouldn't clog the injector. I wasn't thinking about it properly. Well, back to square one i guess. Already ordered the FI cleaner, so might as well clean the injector just to make sure. Edited November 8, 2015 by JFoVStar650 Share this post Link to post Share on other sites
Spud786 Posted November 8, 2015 Intake dirt can definitely cause a seizure, which comes back to a leak down test. Share this post Link to post Share on other sites
