XT350 brake help needed
About a month ago I did full service on my XT350. All fluids changed, grease, etc.
I drained brake fluid. I loosened caliper to check pads. Pads were fine.
Replaced brake fluid and proceeded to bleed brakes. I could not get brakes to bleed. Tried for an hour- nothing.
Next night I went out to garage and found puddle of brake fluid on floor. Front brake cable wet.Replaced hose.
Tried bleeding brakes-nothing. I then noticed that after I tightened bleed screw the fluid was actually going back into caliper.
Bingo- faulty bleed screw. Replaced bleed screw and removed brake line and double checked washers.
Just tried for an hour- nothing! !!!!
The fluid is no longer moving back to caliper. I pump brake lever 15-20 times, hold and loosen bleeder.Watch for bubbles. Close bleeder. Release handle.
I am out of ideas.
Anybody have any?
I have refilled the reservoir 3 times with no air bubbles.
I've done this before on my bike- was never a problem
I spent days trying to bleed the brake on my xt600. Finally used a mityvac to back bleed em. Took about half an hour. Did you bleed every connection?
Edited by slash09
