Exhaust stud removal
The only 3 methods I know of are double nut, weld a nut on or using a stud removal tool. Penetrating lube and heat will help.
Okay cool . Just double checking that they are threaded not pressed In?
Keep in mind, if you cannot do it, take it to a machine shop and pay $10. Too many have been determined to get something like this out and made a small problem worse.
I certainly recommend you try (and google 'Frozen Stud', 'Stuck Stud Removal' for both articles and Youtube instructional) but keep an eye on when your efforts are not working (this time) and let a pro do it.
Jeeper beat me to it.  However you can break studs off with these if it is stuck in the casting.  A little heat may be needed.
One of these, they work every time:
