frederick1977 Posted November 3, 2015 Hi...my rm 250 has a problem when idling hot. The revs pick up and then falls down by itself. It start fine and idles fine but about 10 to 15 minutes into the ride it starts doing this. Also if i keep it idling and turn the fuel off when hot, it will keep reving up and down and then suddenly rev real high just before it dies...your help will be much appreciated!!! Share this post Link to post Share on other sites
DirtBiker Posted November 3, 2015 You are running lean on your pilot. Go to the next larger size pilot. Share this post Link to post Share on other sites
frederick1977 Posted November 4, 2015 I'll check it this afternoon...if its over heating then i must have damaged something? Share this post Link to post Share on other sites
frederick1977 Posted November 4, 2015 It definitly over heated....its now spurting water out the exhaust? Share this post Link to post Share on other sites
frederick1977 Posted November 4, 2015 I'll have to open up and see if the cylinder got hurt...i hope not...i'll check the hoses...i also have a boil bottle on there could that cause any problems? Share this post Link to post Share on other sites
78SuzyQ Posted November 5, 2015 (edited) Hi...my rm 250 has a problem when idling hot. The revs pick up and then falls down by itself. It start fine and idles fine but about 10 to 15 minutes into the ride it starts doing this. Also if i keep it idling and turn the fuel off when hot, it will keep reving up and down and then suddenly rev real high just before it dies...your help will be much appreciated!!! Yea that's what happens when your bike runs out of fuel sucks in air and dies Edited November 5, 2015 by 78SuzyQ Share this post Link to post Share on other sites
frederick1977 Posted November 5, 2015 Thanks for all the info...much appreciated!! Share this post Link to post Share on other sites
frederick1977 Posted November 5, 2015 A boil bottle is a reservoir bottle when it boils over the water tuns in there and back to the radiator Share this post Link to post Share on other sites
