2013 DRZ burning oil bad....
Whats going on guys.
So my new &%$#@!ing 2013 drz400SM is burning oil bad. It smells bad, I see puffs of oil smoke out my exhaust, and I have noticed it when I check the oil. The bike has 4400 miles on it... I checked the plug and it looked pretty normal so not sure what my problem is. I know 9 times out of 10 if burning oil its the rings, but I was told may be my valves?
I did loop my bike few weeks ago (roughly when I think it started burning oil) and It was hard slam but was only little slow wheelie and it was still running when it dropped. I am thinking when it fell still running it &%$#@!ed the wall or something.
I haven't opened up the head or top end yet.
Regardless I just implulsed brought a 434cc big bore kit LOL.
Kit comes in Tuesday so we will see what the inside looks like then...
Heres some picks
  • Like 2
Valve seals are cheap. You could knock those out since you'll be in the engine anyway. How's your air filter? Is dirt getting past it? Carb sealed to the grommets, no leaks past the filter, etc?
pretty much same thing just happened to me this month..
started smoking bad(video in link).rode it for 30 miles smoked alot...drained oil only 1.3ish quarts(i think) came out..so i tore it down after that 1, 30 mile ride, and the cyl wall was really scored(pics in link)
i also read about it possibly being the valves..but only replaced piston,rings,cyl,gaskets,
it fired up instantly, have over 500 miles on the new piston
no smoke
http://www.thumpertalk.com/topic/1157438-i-got-lots-of-white-smoke-out-my-exhaust/
Edited by 707LAKE
Heres some picks
Oil change not related. In going to guess an air leak introduced mud or and and wore the cylinder out.
I'm going to do a compression test today after work
That will be misleading due to the auto decomp. A leak down will tell you if it's rings or valves. I would also suspect dirt ingestion. How many miles are on the bike?
What did you mean a leak down? Sorry never heard of that and 4300 miles :/
https://www.youtube.com/watch?v=w8DF6bbVW-8
Basically, you are pressurizing the cylinder and factor the amount of loss over time. It can also help you figure out where the loss is coming from. (if you hear pressure escaping from the intake, exhaust, crankcase etc.) You can get cheap testers at Harbor Freight and the like.
  • Like 3
