Center Stand\Lift problems
I have the MSR Pro Lift stand (http://www.motorcycle-superstore.com/28665/i/msr-pro-lift-stand) that I used for my 250X and 250L but trying to use it on my 250R makes is HORRIBLY wobbly.  The bike has already fallen off the stand and I've tried to lift all up and down the bottom.  The bike is bone stock so there is no skid plate.
Anyone else having this problem? If so what center stand\lift do you use to fix it?
Edited by Jstyle
all mx bike stands should work just fine, have you looked under your bike to see why its not sitting level on it?
also find a way to strap the frame to the stand, helps when you are working on it to keep the bike stable.
Make sure its sitting on the frame rails and not on the linkage at the rear.
