1986 Honda HPP exhaust valve service
Hi looking for any tips or help in regards to servicing and cleaning the Honda power port valves.  Been looking for a video on you tube but with no luck. Thanks for any ideas or input.
Do you have a manual? That bike is 30 years old now and I raced one so if I remember correctly the valves move laterally like the pistons in a boxer engine. They were used until 1990 if I recall so you might try checking on those years too. There would have to be a link arm connecting to them from the bottom end and some sort of a return spring. Perhaps you could google cylinder removal to determine how to remove the linkage. Take the hpp covers off (top & sides) and locate whatever "stops" the internal flaps on the outsides of the cylinder. Take photos as you disassemble it for later reference.
My 89 has hpp, there are 4 covers two tops and two bottoms. If ure digging round in there, you will need a gasket kit for all of em. a ball and ramp gizmo works off the water pump gear, a rod from it goes to a rack, the rack has 2 spindles, and runs up to the horizontal sliding power valves, now those valves are encased in valve guides, and from the top there are set screws on top of the spindles , take note of their orientation, if you don't it wont operate correctly, I believe the 8mm screw on either side of the side aeras hold in the valve and guides, those guides and valves must be cleaned and de-carboned, and lubed up! note- I had to grind off the face of the valves because they were worn and hitting the piston!, you best bet is to go to Honda and get a shop manual, you will need it!
