Clutch actuator spinning clutch won't engage
I'm rebuilding a 1994 kx250 at the moment in my spare time and the latest problem is the clutch actuator where the cable is attached to the engine is spinning as if it's attached to nothing
Before this the clutch was hard to pull but it worked fine. then I was out riding, pulled the clutch and I got nothing the leaver just pulled in no resistance and wouldn't pull back or spring back out either
Just asking I'm going to be taking the cases apart soon and I'm wondering what to look for with the actuator thanks
you'll likely see a broken actuator shaft. it's easy to replace with the case side cover off.
