crf450x engine bolts and greasing
Hi I now nearly have my 450c together just need a swing arm bolt. .
What I was enquiring is do you lube the front and bottom and top engine mount bolts ?? .
Do they have washers on both end of the engine mount bolt ?.
I also put gpi hoses on my bike has anyone had any dramas with those and the same as rhk fuel mixture screw. .. do they come loose (rotate) while riding and put your mixture out or should I put the standard 1 back in.
Dies anyone know the correct route for the clutch cable and horstart?
I'd like my clutch to be really soft cause at it sounds likes fraid cable but that is coming from the clutch basket and it's a new cable
Wich grease do you recommend as I have this blue stuff and I don't think it is waterproof but I have read people use boat grease on there dirt bikes
Edited by dale450x2007
