yz125 shift shaft play
So my 04 yz125 runs and drives fine but I've noticed theres some play in the shaft, the shifter doesnt move at all but theres a little play, if you go to shift into gear sometimes It doesnt go all the way unless you drag the clutch a little bit, I'm not sure if the shift things behind the clutch have adjustments on them
